DNXHR incompatibility with Windows 7? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old July 1st, 2015, 07:34 AM   #1
I tried to install the DNXHR / HD LE codec 2.6.0 (free) version in two systems, both with the same versions of Vegas 13.0 and Premiere Pro 6.0: a desktop with Windows 7 Ultimate and a notebook with Windows 8.1.
The system with Windows 7 hasn`t got the DNXHR option to render / export, only DNXHD; but the system with Windows 8.1 show both DNXHR and DNXHD options.
Is there any incompatibility between Windows 7 and DNXHR codec?
Thanks.
Ron German is offline   Reply With Quote
Old July 1st, 2015, 08:12 AM   #2
Re: DNXHR incompatibility with Windows 7?
Is QuickTime installed on the Windows 7 machine?
Old July 1st, 2015, 08:33 AM   #3
Sure it is, otherwise even DNXHD wouldn`t show up as an option, I gess.
Old July 1st, 2015, 11:29 AM   #4
Re: DNXHR Incompatibilitty?
I once did a test of DNxHR on my Vegas 13 build 453, Window 7 machine. Seemed to work fine. Quicktime was able to playback the video and MediaInfo identified the file differently than normal DNxHD files.
Norman Black is offline   Reply With Quote
Old July 1st, 2015, 02:09 PM   #5
Thank Norman, but did you see the DNXHR option when you tried te render (QT) the edited timeline?
Old July 1st, 2015, 04:05 PM   #6
Yes, of course. Can't render DNxHR without that option showing in the render as template dialog.
All I have done is install Quicktime first and then install the Avid Quicktime codecs and then setup the template in the Vegas render as dialog for Quicktime renders.
Old July 2nd, 2015, 12:20 PM   #7
Thank you, Norman. Mistery goes on, in my case.
Old July 5th, 2015, 04:31 AM   #8
This information may or may not be relevant to your situation - but I have no issues with DNXHR and Avid Media Composer on my Windows 7 x64 machine. Haven't tried it with any other NLEs though.
Jody Arnott is offline   Reply With Quote
Old September 15th, 2016, 11:08 PM   #9
Contributor
are you running win7x64? Avid requires 64bit OS
John Mitchell is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
