Considering C300
Hi all wonderful people ... This is my First Posting on this wonderful forum.
I am considering purchasing C300EF to replace my EX1. I have few queries namely : - The Lens line from Canon L series vs Zeiss nCP.2's. I am baffled between the choice. Have read much & tried some lens from both lineup side by side. Results were more or less similar but couldn't convince myself to shell out on Zeiss though the build quality is excellent of CP2. - EVF from Zacuto & other similar brands : confused which one to go for & why ? - RIGS between Zacuto/Cinevat/Chinese manufacturers - Electronic Follow Focus esp if i consider Zeiss I need one which can pull 300degrees of focus turns |
Re: Considering C300
First, let me say you won't regret it. The C300 is an incredible camera. Regarding the lens choices, I have used Canon L glass (and one non-L) and have had stellar results. I am very happy with the Canon glass, with one caveat. The 'stepped' aperture can potentially ruin a shot if you find you need to make a quick change in the f-stop in the middle of the shot. I'm not sure if the CP lenses for EF mount allow for aperture ring adjustment on the lens, or if you have to use the aperture dial on the C300. If you can make aperture adjustments on the lens with the lens ring, then that would be an asset. Is it worth the significantly higher cost per lens? (aside from IQ differences). That would be up to you to decide. I haven't found the stepped aperture with the EF lenses to be a huge problem, but it has compromised a few shots in the past for me. Canon is also coming out with some 'Cinema' branded lenses, and I wonder if these will have smoother aperture adjustment? If you were to go with the CP lenses, then you might want to consider going with the PL mount, unless you still want access to the EF Canon glass as an option.
Regarding the shoulder mount... personally, I can't understand why people want to do this. I have been shooting professionally for nearly 30 years, and I have never had a camera so fun to shoot hand-held as this camera as is. Why? Because apart from the wonderful ergonomics for hand holding, this camera can be pared down to an incredibly small footprint for shooting in tight spaces by losing the handle if necessary. Let me tell you, shooting this camera with something like the 8-15mm in a really tight spot like the cockpit of an small aircraft or car is a blast. (of course if you lose the handle and LCD both, you have to figure out an audio alternative since you lose the XLR inputs when the LCD comes off... this is also a bit of an issue, but not a deal killer) Now, having said that, you're probably not going to do much telephoto work with this camera hand-held. I could see where a shoulder mount might be handy there, but honestly, hand held telephoto? That's where your tripod comes in. (although not out of the question, since the 80-200 2.8L IS is spectacular, and allows for very respectable hand-held long lens work hand held due to it's incredible image stabilzation) It's also easy for me to forgo the shoulder mount as I have other cameras dedicated to that kind of work. Bottom line is, you won't be sorry with the C300, but you will have some minor operational quirks that you will have to adjust to. It's worth it though. |
Got my C300ef Now the quest is on for Lens ...
Zeiss vs Canon L ? - Are Zeiss Cp2 Glass worth the extra Extra $$$ - Are Zeiss Cp2 sharper crisper better in color then Canon L - Thinking or say wishing to get 18-25-35-50-85 EF Mount Of cource but yeah CP2 has optional mounts to change EF to PL on the fly if need be - need real reason to go for CP2 (which i wish to) Mush Happier ... |
Roger,
When I'm trying to decide between lenses, I find it helpful to see some examples. Shot with Canon L glass [ , , , , ]: Shot with Zeiss CPs [18mm T3.6, , , and 85mm T2.1]: The grades are very different - but I like the CPs. Canon glass is too clinical for me. Hope this is helpful, Bill Hybrid Camera Revolution |
I've been shooting with the C300 for a few weeks now. If I hadn't bought it before the C100, I'd be thinking hard about waiting for the C100. I believe the C100 addresses some ergonomic problems the C300 has. That is not to say the C300 is bad ergonomically, I just think the C100 could be better for run and gun shooting.
The biggest problem I have with the C300 is that I find it too heavy to shoot for long periods of time with the LCD/audio unit attached. It also changes the balance of the camera, making it too front heavy. So the result is I shot with a VideoMic Pro going into a Y-adapter with my wireless. First, the audio quality of the VideoMic Pro is lacking, secondly I don't have a dial to adjust audio levels. I made a key shortcut, but still it is a lot slower making adjustments and I can't adjust the channels independently. Also, I don't like the way they positioned the buttons. The ND filter buttons (which I use rarely and never during a take) are in the prime position when they should be relegated to a more out of the way place. I want the buttons I use WHILE filming to be in prime position. I have also numerous times accidentally hit the ND buttons while reaching for the 1-4 buttons, thus ruining my shot. The ND filter buttons are in a much better place in the C100. Also, since I don't shoot with the monitor attached, I can't take the unit off my eye. For overhead shots, I just aim and pray. The C100 always has a monitor attached when you need it. It seems like the viewfinder might be lacking. So the ideal setup with the C100 might be a flipable loupe attached to the LCD. The codec of the C100 is the real rub. That's what makes the getting the C300 worthwhile. But if you can live with AVCHD... |
Roger-
If you are thinking about the CP2s, don't forget to take a look at the new Canon CPs....the 24 & 50mm are shipping and the 85mm starts shipping by the end of this month....and they are really nice and super speed fast ...24mm 1.5, 50mm 1.3, 85mm 1.3........ Jim Martin Filmtools.com |
Bill, thanks so much for posting those 2 clips, exactly what I was looking for. That's a really big difference in image, like having 2 different cameras! And I agree with your "clinical" assessment, but I can see where both looks would be useful. Now if I could see some Canon prime cinema's footage I'll have some real info to help with my decision.
I believe that CP2 would be better in terms of Bokeah etc simply cox of Zeiss 14Blade vs 11Blade of Canon Cinema Lens... More over CP2 would be long term investment simply because of the interchangeable mounts EF-PL-Nikies vs Canon only EF ...
50-85 T2.1 ... On its way ! Still debating 18mm APH size lens ??? Since Zeiss doesn't support Screw in filters so i need to go for 4x4 filters for protection & other speciality use. Which one & which brand ? Soft Focus or UV or etc etc... Help appreciated !!! What additional benefits should user expect if they were to use CD NanoDrive with C300 at Higher ratio rates. instead of 50mbps we record at 440mbps though still locked at 8bits |
Re: Filters ???
Roger the NanoFlash only goes up to 280Mb/s and that's overkill IMHO. If you were to use a NanoFlash at 100Mb/s you would see slightly reduced artefacts in the recorded image, mostly a reduction of mosquito and quantisation noise. In every day use you would probably struggle to see any obvious improvement, but when you start doing any heavy grading work you would most likely see a reduction in banding and noise in the 100Mb/s footage compared to the 50Mb/s footage. The majority of banding seen in graded footage from cameras with low bit rate codecs tends to come from compression artefacts and noise rather than lack of bits.
Re: Filters ???
Sure I might have been wrong with 440mbps on NanoFlashDrive. Sure am thinking into investing into one provided it gives me a viewable/noticeable difference !!!
As for Chrosziel 450W I will look around for the same. BUT when it says 16mm I feel confused with it ... isint the c300 a Super35mm senson hence the viewable area ? I somehow couldnt find any screwable filter even though at 2000$ for my Zeiss CP2 primes !!! |
