MXF File Details
Hi, I shoot on the C300 Mark II and often on a job I will shoot both 4K and HD. My problem is when I come to open the file explorer to look at the files there are no property details for each file (ie each file does not provide any information like dimensions). For other cameras/file types if I open a card each clip will display the dimensions in the clip properties. Does anyone know how to make this work for MXF files from the C300II? It would be very useful if I could see which clips are 4K and which are HD (which if the clips had a dimensions field) would be simple.
Thanks, Matt |
Re: MXF File Details
XF Utility does this but you have to open the program to sort the files.
