-   Canon Cinema EOS Camera Systems (https://www.dvinfo.net/forum/canon-cinema-eos-camera-systems/)
-   -   Card stopped recording while dual record is on. Why? C100 mk2 (https://www.dvinfo.net/forum/canon-cinema-eos-camera-systems/533853-card-stopped-recording-while-dual-record-why-c100-mk2.html)
Arthur Abramov April 3rd, 2017 01:21 AM
Hi,
Why does the c100mk2 has this thing going on sometimes? Stop recording and says "card stopped recording". Then I switch to media and there is a question mark on the files. What is the meaning of that, is the card needs to be replaced or something wrong with the body?
Help.
Gary Huff April 3rd, 2017 03:26 PM
Re: Card stopped recording while dual record is on. Why? C100 mk2
Why have you not tried a new card to see what happens?
Arthur Abramov April 4th, 2017 03:41 AM
i used a my friend's card. might be that something was wrong with his card that jammed the system? The camera stopped recording on both cards. very peculiar.. I should contact Canon service for that.
Roger Gunkel April 4th, 2017 04:16 AM
Your friends cards could be too slow write speeds for the camera and just can't handle the data. You really ought to have your own cards to go with your own camera and they should be able to handle the data transfer speeds shown in the manual.
I wouldn't bother contacting Canon service until you have tried cards that you know are suitable.
Roger
Arthur Abramov April 4th, 2017 05:38 AM
Roger, the card was identical to mine it was Sandisk 95mb.
The only reason it would stop recording, is a failure of the card or the body. I need to know which of these were the reason for that.
Roger Gunkel April 4th, 2017 08:15 AM
It makes a big difference what data rate you are recording at, do you know what that is for the setting you are using? You also need to check the write rate of the SD cards as they often have the maximum read rate in print on the front, and the write rate could be much lower, in this case possibly in the region of 30mbs, manufacturers aren't always clear on the actual speeds. I use Sandisk as they are reliable, but different grades of their cards give widely varying write speeds, as do other manufacturers.
Roger
Seth Bloombaum April 4th, 2017 09:07 AM
And, there are many counterfeit cards available on the big auction site and from other sources. Unfortunately, if your friend didn't buy from a known-reliable retailer you really have to do read/write tests.
Good cards are so inexpensive these days, it is really *not* worth trying to save $2 or $12 to get them even cheaper.
And, did you format the card(s) in the camera?
I agree with other contributors. Cards are the first, and perhaps only suspect with issues like this.
Gary Huff April 4th, 2017 11:21 AM
If your friend's card was bad, it would stop recording on both. The whole point of dual record is to record to both cards at once. Why do you think the camera would just continue recording at all if one of the two cards it is supposed to write to (because you enabled DUAL CARD RECORD) would fail?
Pete Cofrancesco April 4th, 2017 08:11 PM
I've thought about doing away with my external record and rely on dual card but this shows a weakness. Av output continues even if there is a card failure.
Whenever you're thinking of cutting corners shooting video...don't.
Gary Huff April 5th, 2017 08:25 AM
It's not really a weakness though because it was never supposed to be a safety feature. The primary reason for dual card record is so that you can hand off an identical SD card at the end of a shooting day to the client.
Arthur Abramov April 5th, 2017 09:48 AM
I think it's a safety feature, if incase one of the cards malfunctions so you have a back up.
Pete Cofrancesco April 5th, 2017 12:43 PM
There are various levels of security. I once pulled a card to deliver to a client and it was lost in the process. I've had a computer card reader corrupt a card. A colleague of mine pulls one card in case someone steals his equipment.
