CF Compact Flash cards - Page 8 at DVinfo.net
Canon EOS Full Frame for HD
Old October 10th, 2009, 08:22 PM   #106
Recommended CF Cards? (Lexar 133x)
I was wondering anyone had some advice regarding a good card to get for video without being overkill.
Currently, I have three Lexar Professional 4GB 133x CF cards, and have been fairly satisfied with the results, but since I haven't been able to compare them to anything, I'm not sure if I'm missing out on any quality or motion smoothness. Are these cards "good enough" to the point where I wouldn't be receiving any benefits from upgrading to something pricier? I'd like to go for at least an 8GB or 16GB if so. I don't care too much about download-to-computer speeds, currently they've been fine. Is this the main benefit of having a UDMA card?
Thanks for your enlightenment.
Sean Parker is offline   Reply With Quote
Old October 10th, 2009, 09:29 PM   #107
if your camera doesnt give you the little buffer indicator and doesnt drop frames, you arent losing anything in terms of quality. if your cards can write 40mbps video then thats all you need. anything faster will just help you read/copy files from the card in a computer or other device.
i use a 32gb transcend 133x card that works well. it can handle 10-15MBps for writes which is plenty for the camera, but it reads up to 40MBps which is fast for such a cheap card, so it is still very fast to download.
Noah Yuan-Vogel is offline   Reply With Quote
Old October 11th, 2009, 03:04 PM   #108
I also use Transcend cause they used to be the cheapest with sufficient performance, but last time I went to B & H they had a Kingston 32 GB 133x for $79.
That's pretty hard to beat I think?
Andree Markefors is offline   Reply With Quote
Old October 11th, 2009, 05:27 PM   #109
Certainly sounds like a darn good deal. Thanks for your thoughts.
Old October 14th, 2009, 11:23 AM   #110
I just loaded up on 32GB Kingston Elites 133x from B&H. I also have a dozen other Elite 133x's and never had a problem with them. They also transfer pretty quick when used with a decent card reader.
Raymond Tsang is offline   Reply With Quote
Old October 15th, 2009, 07:08 AM   #111
Note that these cards will not work in a 1Ds Mark III body. They fail. I've been fighting with Kingston for a replacement for mine (a 16GB). They say they don't support anything bigger than an 8GB in that body. Sigh.
me@facebook: http://facebook.com/stevemallerphotography
Steve Maller is offline   Reply With Quote
Old October 15th, 2009, 10:28 AM   #112
I've also been using these for eight months in my 5D2 without incident.
Bill Binder is offline   Reply With Quote
Old April 7th, 2010, 08:57 AM   #113
I also bought this card a while back and been using it without a problem for a while. But lately, I'm getting lots of "buffer fillups" and this cause the recording to pause. Is anyone facing this problem? Its not that fun when it happens during an important event.
Ram Purad :: Aspiring Event Filmmaker
http://www.butterflysquad.com
Ram Purad is offline   Reply With Quote
Old April 7th, 2010, 09:04 AM   #114
I have the same problem with the Transcend 133X 32GB card I got.
Daniel Browning is offline   Reply With Quote
Old April 7th, 2010, 04:39 PM   #115
Hi Ram
I have the same problem, now, using the kingston elite pro with 16 GB. I think it's because of the increase in the data rate with the new firmware update. Are you using the last firmware update?
Pedro Martins is offline   Reply
