5D MkII Stabilizers
OK. I have seen some awesome footage. However, the Reverie helicopter footage and the aerial footage posted here all used gyro stabilizers or 3-axis gimballs. Not sure if everyone is aware of this, but they START at 2500/- USD.
Now, I do not see myself paying the cost of the 5D Mk II again to stabilize it. So the question is, are there cheaper options to stabilize it ? I looking for at least some dolly moves over concrete, as this is pretty much the basic of what a filmmaker would need. I cannot afford a helicopter shot, but I may mount it on a RC plane if there is a cheaper 3-axis gimball solution. Lets say under 1K ?? Any thoughts out there ? Any DIYs ? For the record, the Homebuilt Stabilizers site has some links The Ultimate in Homebuilt Stabilizers! And here are the plans for Cody's gimbal based stabilizer. The Ultimate in Homebuilt Stabilizers! Has anyone tried these ? Or other ideas ? |
Here is Glidecam's assessment of the Body-Pod: Since the support of the Body-pod is rigid and for the most part inflexible, it will not absorb and smooth out camera movements as well as a stabilizer which is being held in just your hands. However, shooting with your stabilizer attached to the rigid support of the Body-pod still yields results that are far better than unstabilized, hand-held shooting or shoulder supported shooting. Once you get used to using the Glidecam Body-pod, you won't want to shoot anything without it. It appears to me there is no way out of this problem without biting the bullet and purchasing the vest. From other articles I have seen about the Steadicam Merlin (good for 5-8 lbs with their vest), this too requires the vest otherwise your arm and wrist gets tired very easily. The Glidecam 4000 will hold cameras up to 10 pounds. Glidecam Products |
| All times are GMT -6. The time now is 06:39 AM. |
