My 5D MKII Goes Handheld Doc style! - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old June 5th, 2009, 12:27 AM   #16
Originally Posted by Nigel Barker View Post
Dan, how useful is that lens designed for APS-C sized sensors? Don't you get vignetting?
Hi Nigel:
When we meet up, you can check it out and see for yourself. I have made some pretty nice images with it. I am thinking that it will be good for walking around, following my documentary subject through the buildings and museums as well as in the car, trains, etc.
You do not get vignetting at 18.5mm bare (for interiors) and at 21.5mm or longer with the Vari ND attached. I was going to buy a proper full frame wide angle until I realized that I don't really care for many of the Nikons (I have the 28,, 2.8 D, terrible lens) and I cannot afford the Zeiss. The Canons have just started looking good with the new firmware, but once again, I already owned the Tokina.
Dan
Old June 5th, 2009, 12:30 AM   #17
Hi Brian:
I am pretty happy with the look of the footage so far. I have only shot a couple of things so far but the images are good, I like the look.
I need to mess around with the custom picture settings, I am getting sick of the stock 5D MKII look. I would like less crushed blacks, less color saturation and less sharpening so I will be experimenting with developing my own look. I am shooting all over France and I think France will look better through a more Impressionist desaturated palette personally.
Dan
Old June 5th, 2009, 12:35 AM   #18
(Note: Vimeo's change to 24p does cause some artifact issues)
As of yesterday Vimeo now leaves 30fps HD footage alone & doesn't hack it down to a lower frame rate any more. Vimeo HD now MP4? in the General Discussion Forum on Vimeo
Old June 5th, 2009, 12:53 AM   #19
Hey Dan, wonderful rig! Maybe a little intimidating for camera shy people!!! ;-DD
That zoom recorder should be horizontal, not vertical. It has a couple of mics in XY, so you can pan them L-R (if recorded horizontal)...
Xavier Plagaro is offline   Reply With Quote
Old June 5th, 2009, 01:07 AM   #20
Thats funny cause I uploaded mp4, and I don't think my original shows the lost frames, but I will recheck.
Edit: Rechecked original, and it doesn't show the issues displayed on the Vimeo playback.
Chris J. Barcellos
Old June 5th, 2009, 01:49 AM   #21
This must mean that Vimeo has screwed up the compression in some other way then. At least the 30fps>25fps horrible conversion jitters & stutters shouldn't be present any more.
Old June 5th, 2009, 08:26 AM   #22
Originally Posted by Dan Brockett View Post
Hi Nigel:
We will be able to compare it to the Tamron 20-40mm F2.7-3.5 that I just bought which is a FF lens.
Old June 5th, 2009, 09:56 AM   #23
Hi Brian:
Dan
Someone mentioned a style they'd done recently and allowed us to download or mod it. I have it in my cam and it's nice. Just the things you mention, less crushed blacks, slightly less saturation and not quite as sharp. Neucon I think it was called. It'll be on this forum somewhere
Avey
Wayne Avanson is offline   Reply With Quote
Old June 5th, 2009, 12:35 PM   #24
Thanks Avey, I'll hunt down and give it a try.
Dan
Old June 5th, 2009, 03:43 PM   #25
It's here Dan. From Luis de la Cerda in the Optimum Color Temp thread.
It's subtle but I like it. anyway, he says that we're free to mess with it how we want, so maybe it's a good starting place for your tweaking.
Avey
Old June 5th, 2009, 07:10 PM   #26
Thanks Avey. You are making it too easy for me. Now if I only didn't have a show and two articles due, I could get out my 5D MKII and mess about with with it. I have been to busy to even update the firmware yet!
D
Old June 6th, 2009, 03:33 AM   #27
Dude,
your priorities are all wrong man…
Old June 6th, 2009, 06:47 AM   #28
Avey
Thanks Avey...
Old June 7th, 2009, 12:48 PM   #29
my new 5D set up
total set up cost me around 500 bucks
My 5D MKII Goes Handheld Doc style!-img_3971.jpg   My 5D MKII Goes Handheld Doc style!-img_3972.jpg
Minh Khang is offline   Reply With Quote
Old June 7th, 2009, 02:14 PM   #30
Originally Posted by Minh Khang View Post
my new 5D set up
That Vizio monitor might be a little cumbersome for run and gun.
Seriously, did you fabricate the pieces? Looks good.
Brian Luce is offline   Reply
