| Canon EOS 5D Mk. II for HD All about using the Canon 5D Mk. II D-SLR for HD video recording. |
#16 |
Shows as 0.1.4 for me...
CH Search DV Info Net for quick answers | The best in the business: DV Info Net Sponsors | ...Tuesday is Soylent Green Day! |
#17 |
It's probably your browser cache that needs flushing or try force reloading the page. If that doesn't work then I have attached the file you want that I just downloaded from the wiki.
#18 |
Thanks Chris and Nigel.
I had been reloading the page, but I just tried it again right now and, what do you know, it's showing the 0.1.4 file. So I've downloaded it. Appreciated. |
#19 |
double post, please delete.
Chris J. Barcellos |
#20 |
Magic Lantern 0.1.4 users be aware that if you shut down or let the camera time out in this version while you are in the menu mode, you may not get a complete shut down, and you will have to pop the battery out and reload it.
Also, when camera is shut down, on next reload you are back to defaults. Hopefully, in future version, Tramm will find a way to make your Zebra gain settings stick....
#21 | |
Wizard Status
Another step that I need to try is to open a file on "C:/", which appears to be some sort of in-memory filesystem. If it is also in the NVRAM, perhaps that would be a safe place to store all of our settings. |
#22 | |
#23 |
For what it's worth, I have absolutely *no problem* with having to manually set up a specifically called files / folder structure for each CF card that I'm going to put into the camera... in addition to copying ML to each card.
#24 |
Wizard Status
#25 |
As I suggested before, with the small file size, one could keep a subfolder of various versions of ML, on each chip, and drag an drop the one with the settings into root before start up. I know with the variables starting to grow, this will get to complicated, but maybe kind of editable string for the user to set up on the CPU system, that automatically writes the wanted values into the version of ML.
#26 | |
One thing to keep in mind is forward compatibility. As new versions become available, we would want our previous config files to still be valid. And you probably don't want to write version converters, or burden the code with the reading of bunch of completely unique formats/versions. Unless you're designing Microsoft Word, of course. :) Anyway, design that first config file with great care. You might have to live with it for a long time... |
#27 | |
Wizard Status
I think we'll have a simple text INI style file initially, but ideally we would move to a script based setup. So at startup the Magic Lantern firmware would look for a autoexec.pl (or .py or .scheme or something) to initialize all the parameters. That way the complexity of configuration is moved out of the "hardcoded" C code and into an end-user editable format. |
#28 |
Sounds right to me ! By the way, I think in some situations we will want to turn off zebras, so that option should be there at some point..
#29 | |
Bruce |
#30 |
Wizard Status
0.1.4 sources now online
For the truly adventurous, fool hardy and other mad men, the Magic Lantern 0.1.4 sources are now posted: Download Magic Lantern sources.
Even more than the pre-built and tested binary firmware images, these sources are potentially dangerous and you can damage your camera. There is no warranty of any kind on this software. There is no support implied. In fact, it is best if you pretend you never read this post and instead look at cute pictures of animals instead. To build the firmware I'm using arm-elf-gcc 4.3.2 on Mac OS X and arm-linux-gcc 3.4.4 on Linux. Beyond that I can't make any promises of things compiling or working. You must also have mercurial, perl, make, binutils, etc. There is no support for cross compiling from Win32. Due to copyright issues with Canon's firmware flasher, you must supply your own 1.0.7 firmware image if you want to build the ROM dumper. The only top-level Makefile target of interest is magiclantern.fir. The sources are GPLed, but any commits to the main tree must be accompanied by copyright assignment. Good luck and be careful. |
