15mm rod-clamp...? at DVinfo.net
Canon EOS Full Frame for HD
Old June 24th, 2009, 07:19 AM   #1
15mm rod-clamp...?
I somehow lost a bookmark for an inexpensive 15mm x 60mm rod-clamp. Need a couple of those for my new carbon rail-rig. Any help/pointers appreciated.
-- peer
www.NoPEER.com
Old June 24th, 2009, 10:41 AM   #2
DFocus with DesignbyDave might get you there. Google that.
Chris J. Barcellos
Old June 24th, 2009, 12:28 PM   #3
Cinevate Universal Rails Blocks for 15mm Carbon Fibre
Cinevate Inc.
Carlos Padilla is offline   Reply With Quote
Old June 25th, 2009, 04:32 AM   #4
Yes, it was the Cinevate clamp I had bookmarked -- thank you Carlos. However, thanks to Chris, I went with the DFocus (although it might look funny next to my RedRock parts ;^)
Thanks to both of you for a quick reply.
-- peer
www.NoPEER.com
Old June 25th, 2009, 03:40 PM   #5
Peer:
They just give you the block, and you go down to OSH and get whatever tighting bolt and length you need. I used one to put add a shoulder brace, I tight wing nut on one end.
Chris J. Barcellos
Old June 25th, 2009, 10:58 PM   #6
Peer: They just give you the block, and you go down to OSH and get whatever tighting bolt and length you need.
Yep, but I'd prefer using a standard threaded camera bolt -- anyone knows were I can get hold of lengthy ones of those?
-- peer
www.NoPEER.com
Old June 25th, 2009, 11:02 PM   #7
actually the camera thread is a stanard thread. Forget size, but is easy to match.
Chris J. Barcellos
