Night shoot - help needed - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old October 1st, 2009, 05:20 PM   #16
Hi all,
I had another shoot last night. I set the following:
1/60 - 1/40 when light was too low.
f2.8
ISO - 1250
The footage looks lovley and noise is acceptable IMO. However, when I play it in FCP it doesn't look perfectly smooth - its as if it slightly stutters/jitters but camera is on a rock solid tripod and there was no movement. Can anyone tell me what is the story? I never see this in footage I get with the EX3. WHat is the way to view footage from the 5D Mark 2 using FCP? Do I need to somehow manipulate it or should I expect it to play as it really is when just opened.
Ofer
Ofer Levy is offline   Reply With Quote
Old October 1st, 2009, 05:30 PM   #17
Image Stabilization?
Perhaps your lens has image stabilization, and that was switched on. On a tripod, IS will make for some subtle movement sometimes.
Maybe?
Stephen Mick is offline   Reply With Quote
Old October 1st, 2009, 07:34 PM   #18
Thanks Stephen, I used the Canon 24-70 which does not have IS so this is probably not the reason.
I suspect it is the way I try to play it on FCP.
Ofer
Old October 1st, 2009, 08:06 PM   #19
Problem solved!
Well, it is just my lack of experience with the 5D/FCP....(-:
Saved the clip as Apple ProRes 422 1920x1080 30p 48kHz and then palyed it again in FCP and it palyed beautifully!
Will put together a short clip and upload it soon.
Thanks guys - this forum is just fantastic with so many pros with such a great attitude and willingness to help.
Cheers,
Ofer
Ofer Levy Photography
