Edius 5 and 5D at DVinfo.net
Canon EOS Full Frame for HD
Old February 8th, 2010, 08:26 AM   #1
Edius 5 and 5D
Hi,
Can you use Edius 5 for Canon 5D projects, if so do you hae to convert them first, is there any where I can learn about it, I searched every where but no luck.
Cheers
Mitchell
Mitchell Yazdani is offline   Reply With Quote
Old February 8th, 2010, 09:05 AM   #2
Hi Mitchell,
Yes, you can use Edius 5 for Canon 5D projects. Check out my work at:
cuongdinhvideo on Vimeo
All the video you see on my vimeo edited by Edius 5 and capture by Canon 5D.
I use Procoder 3 to convert the video to HQ codec and change frame rate to 29.97 after that import the video to Edius 5 ... realtime ;)
Cuong Dinh Video
weddingfilmhd.com
Cuong Dinh is offline   Reply With Quote
Old February 8th, 2010, 04:30 PM   #3
batch convert
So does batch convert to hq work for you? Can you share your settings for procoder?
I have struggled with a work flow, but I guess I do not have procoder 3. Are there any other settings you use for the HQ codec?
George Sickler is offline   Reply With Quote
Old February 8th, 2010, 06:50 PM   #4
Thank you for the reply, please kindly send your Procoder's settings.
Cheers
Mitchell
Old February 8th, 2010, 07:01 PM   #5
Canopus HQ is only 1440 x 1088, can I convert it to H.264 (MP2TS) 1920 x 1088i 25p as I am in Pal land?
Old February 8th, 2010, 08:20 PM   #6
I have been trying to batch convert but Edius crash's. I will have to look at Procoder vs neoscene. I wish Mpeg Streamclip would output Canopus!
Geo
Old February 8th, 2010, 08:47 PM   #7
I converted some of the 5D files to Canopus HQ using Procoder and it increased the size by about 25 times. A 89Meg files increased to 2027Meg, is that right?
By the way you can batch convert with Procoder but the problem is that with the setting that I used the files sizes are extremely large.
Same Day edit using Premiere Pro CS4
http://exposureroom.com/members/austcoll
http://www.iconfilmproductions.com
Old February 9th, 2010, 08:36 AM   #8
I using PP3 to do batch convert all my 5D clips never crash in my computer. Here my setting in PP3:
* Video Encoder: Canopus HQ Encoder
* Width: 1920
* Hight: 1080
* Frame Rate: 29.970
* Interlacing: Upper/Top Field First
That is it. Work like charm. Real Time.
Cuong Dinh Video
weddingfilmhd.com
Old February 9th, 2010, 02:14 PM   #9
Thank Cuong for the info, also is the size file xcorrect, Procoder increased the size by about 25 times?
Old February 9th, 2010, 04:26 PM   #10
I really don't know about it. :)
Cuong Dinh Video
weddingfilmhd.com
Old February 9th, 2010, 06:03 PM   #11
When you convert your files do they get a lot larger too?
Have you ever tried importing Cineform converted AVI files to Edius, does it work?
Cheers
Mitchell
