-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Canon EOS Final Cut Plugin will work with T2i (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/475295-canon-eos-final-cut-plugin-will-work-t2i.html)
Bryan McCullough March 21st, 2010 06:05 PM
Borrowed from the 7D forum:
To get the FCP EOS Plugin to work with T2i footage…
1. Install the new Canon EOS MOVIE Plugin-E1 for Final Cut Pro (http://www.usa.canon.com/consumer/co...nloadDetailAct)
2. Go to Library/Application Support/ProApps/MIO/RAD/Plugins/CanonE1.RADPLug/Contents/Resources/
2. Open up cameras.plist
3. After the 7D info add the following lines of code (keeping to the coding structure):
<key>T2i</key>
<array>
<string>Canon EOS REBEL T2i</string>
</array>
4. Save the text file. Close it. Everything should work now.
Have tested it and it works.
Scott Brickert March 21st, 2010 08:53 PM
Any chance for a revised link...that one doesn't seem to work.
thanks
Bryan McCullough March 21st, 2010 08:57 PM
Canon EOS 7D Digital SLR
James Miller March 22nd, 2010 03:32 AM
Pipped to the post on that one.
'Cameras.zip'
Download at:
http://files.me.com/jamesfilm/eo665w
Supported Cameras:
Canon EOS-1D Mark IV , Canon EOS 5D Mark II, Canon EOS 7D, Canon EOS REBEL T2i (US) Canon EOS 550D (UK), Canon EOS REBEL T1i (US), Canon EOS 500D (UK)
1. Install the new Canon EOS MOVIE Plugin-E1 for Final Cut Pro.
Available from the Canon website.
http://gdlp01.c-wss.com/gds/5/020000...e1100x.dmg.zip
2. Type this in Safari web address: //Library/Application Support/ProApps/MIO/RAD/Plugins/CanonE1.RADPLug/Contents/Resources/cameras.plist
2. Replace the cameras.plist with the supplied version.
This code lists both US & UK Canon DSLR cameras with video recording functions. Crop mode is not supported on the T2i/550D.
Christofer Thelin March 22nd, 2010 04:54 AM
Works like a charm =)
If your on a 550D (euro modelname of the T2i) i´ve put up a guide and a screenshot from the correct edited file.
Sorry the text is in Swedish but just look at the screenshot and I´ll bet you see whatsúp
SkullFilms Productions: Canon 550D hack (EOS Plugin FCP)
Ned Soltz March 22nd, 2010 05:30 AM
+1
Works like a charm.
Note that Canon states that 10.6 is required however I am running 10.5.8 and the PLIST mod works in FCP 7.01 with my T2i!
Craig Campbell March 22nd, 2010 06:36 AM
The files from my 500D show up in Log and Transfer but they give an error every time I try and transfer, anyone had any luck with this camera yet? Thanks
Craig
Luke Tingle March 22nd, 2010 07:10 AM
works great! thanks for the plist. Now hopefully Aperture will support the T2i Raw files soon.
T2i, FCP 6.06, OSX 10.5.8
Mark Slocombe March 22nd, 2010 08:55 AM
[QUOTE=Ned Soltz;1503399]+1
Works like a charm.
Ned and others - What is the alpha setting in the ProRes LT files you guys are getting? Mine come out with None, and a change to Straight makes clips visible but needing Unlimited (orange) rendering in timeline...
Mark Slocombe March 22nd, 2010 10:24 AM
Fully solved my problem - trashed FCP prefs and default Alpha is None/Ignore, but clips now play fine...
Daniel H. Buchmann March 25th, 2010 05:46 PM
worked great for me. Thanks a lot!
Mike Juhl May 12th, 2010 08:52 PM
Just bought a Canon T2i and love it. Trying to capture video to FCP doesn't work...OK. I find and install the Canon plugin as outlined previously. I see that I need to edit the .plist but can't find it. Following this path
I can't get past the Application Support folder as there is no ProApps folder. Anyone have any ideas why or what I can try next?
I have Snow Leopard and FCS 3 all with the latest updates.
mj
Mark Slocombe May 13th, 2010 12:11 AM
You only need to edit it to add the 550d, as I recall, but you will find a link to the info if you search Canon or 550d on my blog, at web address below. I found a Mac restart helped the install, too.
Nathan Gogol June 13th, 2010 12:32 AM
any T1i luck
Hi there, stumbled across this thread trying to figure out how to get my footage logged to final cut. This thread says it does support the T1i. Nothing on the net says it does. Anyways, I installed it but when I turn my camera on and go to log and capture it doesn't recognize it at all. iphoto always opens to so don't know if that matters but has anyone had luck with the t1i. Thanks guys
Per Johan Naesje June 13th, 2010 01:40 AM
You could try a cf-card reader instead of connecting the camera itself
