Best for Video: 7D or 5d MK2?? - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old March 30th, 2012, 11:37 PM   #16
Re: Best for Video: 7D or 5d MK2??
Hi Al,
You mentioned the addition of an Anton Bauer eclipz. Can you provide a link to this product if this is ok with the site managers?
Does this system do away with the Canon batteries? If so, this may be what I'm looking for as I use a lot of Canon batteries on a full day of shooting.
Cheers
Old March 31st, 2012, 02:47 AM   #17
The 7D is a poor choice for video unless you need rugged weatherproofing. It uses the same batteries so if you already owned a 5D it might be an option. The video is the same quality whichever APS-C Canon DSLR you choose so a 7D will be no better than your current 600D. The 5D has much better low light performance & a better choice of wide angle lenses plus the whole full frame shallow DoF look that is so attractive.
Old March 31st, 2012, 05:44 PM   #18
Bokeh is often a figment of a clients imagination...or more likely the real affect of slightly more DOF in the 7D using lenses with similar FOV. :)
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old March 31st, 2012, 10:22 PM   #19
I've understood what Bokei is, thanks. The jello issue I always attributed to people describing some aspects of bokei, but likely I just misunderstood. I have thought that the DOF was great with the 5, I liked it's bokei, but hearing some clients complain, I realize it's pushing the envelope about what some people expect.
Al
Upper left hand corner of the map
Al Bergstein is offline   Reply With Quote
Old April 1st, 2012, 03:38 AM   #20
the 5D also has slightly more dynamic range than the 7D, which is never a bad thing...
Brian David Melnyk is offline   Reply With Quote
Old April 1st, 2012, 06:57 AM   #21
Depends what you shoot.
If its anything longer than 12 mins you need Magic lantern to auto restart.
Without it the camera becomes useless.
7d has no ML
Ger Griffin is offline   Reply With Quote
Old April 1st, 2012, 09:39 AM   #22
You might be right Tony, but it sure seemed that when things were out of focus (backgrounds) on the 5D they were way more like "jello" than on my similarly equipped 7D at about the same FOV. He could have had a 1.8 as compared to my 2.8 I suppose. That could affect the look and feel. Whatever, the client did not like it and said so.
Simon, I have been less than accurate this week in my posts...(G). It's ELIPZ that I have.
Anton/Bauer - 7.2V Camera Batteries and Accessories
(I have no commercial interest in this product)
Yes, it replaces the battery, by using the Canon AC adapter (I don't remember the part number), you have to undo the battery door, and the cord slides through a little slot next to the door. Then you plug the cable into the ELIPZ adapter instead of into the AC adapter. The battery is big enough that you will have to mount it on a rail system, figure out a mounting bracket for the thing, or it can mount under the camera. AB has thoughtfully designed it to have a screw mount underneath and a removeable camera tripod mount on top. It's a little awkward but does the job. Would likely work as well with the 5. If you need a lot of power throughout the day, and you are not doing run and gun, I think it works well.
Yes, the 5 is better video quality overall, from what I've seen on friends 5's. And yes, I've had some low light experience on dimly lit stages with the 7D and I do agree that it would have been nice to have the 5's larger sensor.
This short video sampler for an indoor bluegrass festival was shot with my 7D entirely. As you can see, some of it is not great,(especially stuff under fluorescent) and some really nice, with stage lighting. Handheld or using a monopod. I shot this and edited it on site the same day, so I didn't spend a lot of time color grading it. (which is why I post it, as it reflects a pretty much normal output of a 7D under typical inside low light before a lot of post). It was a quick turnaround to boost attendance.
Al
