Best for Video: 7D or 5d MK2?? at DVinfo.net
Canon EOS Crop Sensor for HD
Old March 29th, 2012, 05:02 AM   #1
Now the 5DM3 is out the price of the M2 will start to drop significantly over the year, so which is best for HD video? Old question I guess, but so far I have been using a 600D and I am impressed with the output.
Any suggestions of which is worth to upgrade to? 7D's are going new for a body in this part of the world for $1300 and 5D2 for around $2K.
Lee Mullen is offline   Reply With Quote
Old March 29th, 2012, 06:40 AM   #2
Re: Best for Video: 7D or 5d MK2??
Unless you get caught in the rain a lot (which might be a real possibility considering your location), a 7D isn't an upgrade, I would even consider it a downgrade since you have no audio control, and the LCD doesn't swivel. I have the 7D and the 600D as well.
I would suggest loading Magic Lantern on the 600D, that alone is a huge upgrade and makes the 600D many times better for video. Focus peaking and more iso adjustments were the big ones for me.
Kin Lau is offline   Reply With Quote
Old March 29th, 2012, 08:09 AM   #3
To be fair, the LCD on the 5D Mk. II doesn't swivel either, so I don't think the
7D should be faulted for that if we're only comparing these two cameras.
Here's my take on this decision:
Video recording is pretty much *the same* across all of these Canon D-SLR's.
So it really comes down to the differences in features and price.
Do you need a swiveling LCD display? If so, choose the EOS 60D.
If you've already narrowed the choice down to the 5D Mk. II or the 7D, then the
biggest difference between these two is the sensor size (Full Frame on the 5D2
vs. APS-C crop on the 7D).
The advantage of the 7D is that the crop sensor size is equal to having a 1.6x
extender built right into the camera -- it's always there. This is helpful if you do
a lot of telephoto work at long focal lengths.
The advantage of the 5D2 is the exact opposite: it's easier to get high-quality
wide-angle focal lengths, through the excellent L-series lenses. It's true you
can use these same lenses on the 7D, but you lose the wide-angle field of
view due to the smaller sensor size. There is a wide-angle zoom lens made
for the 7D and 60D, but its quality is inferior to an L-series lens.
Do you need high-quality wide angle? If so, choose the 5D Mk. II.
Do you need extended telephoto? If so, choose the 7D.
Do you need a flip-out LCD? If so, choose the 60D.
Hope this helps,
Old March 29th, 2012, 08:31 AM   #4
Back when I was choosing between the two, the 7D won out due to the hdmi out staying HD during recording and that I do a fair amount of action still work so the high fps in still mode was a necessity.
They do have a different look to the image but quality is about the same. I shot and edited a season's worth of tv episodes with a friend who has a 5D and they cut nicely. I'd say save your money, get the 7D and get good glass.
Old March 29th, 2012, 08:48 AM   #5
...The advantage of the 5D2 is the exact opposite: it's easier to get high-quality wide-angle focal lengths.
That is one of the biggest reasons of all for me to use the 5D over the 7D.
A second reason is that buying a range of quality full frame 'L' lenses for the 5D will last for years to come, even with upgrades to new bodies, but if you buy special wide-angle lenses for the 7D you'll need to sell them and buy new lenses if you upgrade to full frame in the future.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old March 29th, 2012, 08:52 AM   #6
There are certain things one can't replicate with the 7D. For example, the 5DII with the 24L is something that doesn't exist with the 7D. Then again, 200mm on the 7D is MUCH further out than a 200 on the 5DII... I shot action sports and motorsports, so naturally it was the 7D for me. A 300/2.8 on a 5DII is mucho pricey compared to things such as the 200/2.8 on a 7D which was my setup for a while.
Justin Molush is offline   Reply With Quote
Old March 29th, 2012, 01:54 PM   #7
if you already have the 600D, the 5D is the easy choice.
plus i hear it is ok for photography, if you like that kind of thing.
Brian David Melnyk is offline   Reply With Quote
Old March 29th, 2012, 04:16 PM   #8
IMO, none of the current crop of canon dslr's are worth upgrading for. Buying as a second body, sure, but not worth the money to sell your old body and get a new one. My advice is to hang on to your 600D a little while and see what comes next.
Alex Payne is offline   Reply With Quote
Old March 29th, 2012, 06:37 PM   #9
I have both cameras and they both have excellent video quality. I found 7D easier to work in video mode but what really makes 5dII shine is its ability to take far better videos in low light conditions. I think this is because of its larger sensor. I also find the manual sound adjustment of 5DII very useful and actually it improves the sound quality a lot when used with an external microphone compared to 7D.
Pedanes Bol is offline   Reply With Quote
Old March 29th, 2012, 06:59 PM   #10
One other important difference... 7D runs on double processors and it heats up easily and may disrupt your footage during long usage. 5DII doesn't have any heating issues.
Old March 30th, 2012, 06:19 AM   #11
I was only comparing the 7D and 600D which the OP already has.
If one already has the 600D, then except for weather sealing and better battery life, I don't see any real advantages of the 7D over the 600D for video, especially if you load Magic Lantern on the 600D.
Old March 30th, 2012, 11:37 AM   #12
The advantage of the 7D over the 600D is that HDMI stays at 1080 during recording. That could be important if you use a monitor or EVF.
Jon Fairhurst
Old March 30th, 2012, 01:27 PM   #13
if you can budget extra cost of 5D, it's easy to choose, just emagine 5D and 7D cost the same, whch one you want?
I love this place!
Old March 30th, 2012, 06:32 PM   #14
No one has mentioned the Bokei yet, which is different on the 5 from the 7. More 'squishy' if that's the right way to say it. Some folks say "jello" but I don't' find see it that way. I've had clients say they don't like the 'look' of the out of focus parts of the 5 image, and prefer the 7D.
As to overheating, I sold a T2i which had overheating problems for the 7D, and I've never overheated using it, but maybe it's because I'm in a cooler climate? I do sometimes shoot performances that require me to shoot continuous 12 minute clips, so I think I would have seen it. ?
All the other debate points are valid, as to lenses etc. I work in the rain and fog a lot up here so the 7D with it's sealed body (with the right lenses) was the choice. As to the 24 mm on the 5d, I bought a wonderful higher end Tokina that gets me to 16, which seems pretty close. (I like wide angle over telephoto in general)
Whatever you do, I've found the addition of an Anton Bauer eclipz to be really the way to get around the ridiculously short lived batteries. If you are shooting for hours a day, the AB's are a great addition. They run forever it seems. I mount them on rails or under the camera if I have to use it in the field without the rails. I assume you can use them on either the 5 or 7.
You didn't say whether you were shooting theatrical or documentary. That might affect the choice.
Al
Upper left hand corner of the map
Al Bergstein is offline   Reply With Quote
Old March 30th, 2012, 07:18 PM   #15
Bokeh and jello are different.
Bokeh refers to the quality of things that are out of focus in the image. The quality is generally related to lenses.
The 5D2 has a larger sensor, so it offers a shallower depth of field with the same view at the same f/stop. In other words, all things being equal, the out of focus areas of the 5D is more out of focus than with the 7D. But the beauty, or bokeh, of the out of focus areas depends mainly on the lens.
Jello has to do with rolling shutter. The top of the frame is captures before the bottom of the frame. When you pan quickly, vertical lines turn to diagonal lines and look like jello. :)
Jon Fairhurst
Jon Fairhurst is offline   Reply
