September 1st, 2009, 02:20 PM | #1 |
Contributor
Viewfinder
Does anybody know if the viewfinder works when shooting HD, or do you only get an image on the LCD while shooting?
September 1st, 2009, 02:38 PM | #2 |
Because of the way the video recording works, there won't be an image through the viewfinder. It'll be LCD display only. The key to video mode on these cameras is Live View mode, which locks the shutter in the open (up) position, blocking light from reaching the viewfinder for as long as Live View is activated -- and movie recording is available only in Live View mode.
Short answer, 'cause it's an SLR. |
September 1st, 2009, 04:15 PM | #3 |
The viewfinder is still optical as per specs so I assume that you must use the LCD in movie mode.
From DPreview - they have stated that it is the same prism/lens assembly from 1D series and seeing the diagam/illustration it still is optical because none, I mean none of the electronic viewfinders can compete with a bright optical one. Specially so when you consider the 30fps refresh rate. T |
September 1st, 2009, 08:39 PM | #4 |
Contributor
Which means that Zacuto hood/magnifier thing for 400 bucks would probably be necessary for most people. It looks pretty decent.
September 2nd, 2009, 01:52 PM | #5 | |
john |
September 2nd, 2009, 04:00 PM | #6 |
Specifications are identical between the 5D Mk. II and 7D LCD displays...
TFT, 3.0 in., appx. 920,000 dots (VGA), appx. 100% coverage, viewing angle: 170° |
September 2nd, 2009, 04:11 PM | #7 |
For those of us who don't own a Mark II, do you think the LCD screen is good enough, or should a potential 7D buyer also plan on buying a portable monitor for pulling focus?
john |
September 2nd, 2009, 04:17 PM | #8 |
I would say yes you'll probably need one. We have a number of monitor threads in the 5D Mk. II forum (maybe I should copy a few of them over to this board).
September 2nd, 2009, 04:21 PM | #9 |
Thanks! Saving my pennies...
john |
September 3rd, 2009, 11:07 AM | #10 |
John:
Since you don't yet have a 7D, you should be aware that the camera's HDMI output will exhibit 1080 or 720 output when in standby, but when you begin to roll, the resolution out to the monitor will drop to SD when the camera is rolling. You cannot effectively pull focus with SD output when shooting HD, there is not enough resolution to tell if the picture is in sharp focus in HD. So an external monitor, while handy for framing, is kind of somewhat useless for racking focus shots with the 5D MKII or 7D. Dan |
September 3rd, 2009, 11:11 AM | #11 |
Indeed -- thanks for pointing that out, Dan!
September 3rd, 2009, 11:21 AM | #12 |
But as long as we're not moving and can mark the two focus points we setup beforehand it should be good. I don't like pulling focus during a shot unless I have a destination already in mind.
Talenos Productions at http://www.talenos.com |
September 3rd, 2009, 11:34 AM | #13 |
Contributor
That brings up another question--I wonder if you can see a distance readout in the LCD. By having the readout in the VF and screens of the 1/3' chip cameras, a guy can follow focus himself without an assistant in most cases.
September 3rd, 2009, 11:42 AM | #14 | |
Wizard Status
September 3rd, 2009, 12:07 PM | #15 | |
http://www.dvinfo.net/conf/photo-hd-...ef-s-lens.html Or you can watch his video here: Shallow DOF on T1i with Canon EF/EF-S lenses on Vimeo It appears he is using this unit from CAVision: Cavision | DSLR LCD Viewfinder Set for the Canon 5D | MHE52-RCM Mr. Bruce Foreman is using it on the Canon T1i (500D) but B&H lists it as being for the 5DM2, so it will very likely work on the 7D as well. And it's a lot less expensive than $400 USD. |
