What kind of sharpening do you use ?
Hey,
When I shoot on my 7D, I have my settings as flat as possible so I could do everything in post, but a lot of times I found the footage seems really soft. So now I was thinking of doing some sort of sharpening onto it. Do you also do it ? Now I tried the sharpen effect and unsharp mask, but I think the boundary between too little and too much is really small. |
Does that work for video? Or is it only photo sharpening in Lightroom / Photoshop?
Genuine Fractals ?
Isn't that for enlarging pictures ? |
Totally agree with Daniel, sharpen in camera. I'd just add that the extra rendering time required with a sharpen filter isn't fun.
Daniel has a point, but in general sharpening should only be applied on OUTPUT. Furthermore, different displays and different display resolutions require a varying amounts of sharpening. You can apply sharpening in Compressor and similar programs, though personally, I try to avoid it altogether by using sharp lenses with all artificial sharpening turned off.
I've generally never been a fan of sharpening BUT recently, there's been a good shot or two that i was going to purge from my bins because of tad-too-soft focus...yes, my talent moved...1mm...the horror!!
So what i do is mask an area, and sharpen a small patch, i.e: an eye... and it REALLY helps those tad-too-soft focus. Its more selective, you only have to do it a for short period of time to keep people in the moment, say at the beginning of the cut/edit. As for sharpening in-camera, its doesn't really look so good on a large monitor. I find that reducing the sharpness half way, actually increases "the magic' that the camera produces. And setting the in-camera sharpness all the way down, begs for post sharpening, which doesn't make any sense! |
That's why I stay mostly at +1 for in camera sharpnening. "0" is too much.
Edit: What I meant was no sharpening on this camera can be too much. I have to start at +1 or 2. |
The lack of resolution these DSLR's produce they make up for with artificial sharpening which introduces a lot of aliasing... if this makes no sense or you don't believe it, ask Barry Green. I shoot with the sharpness all the way down on my 5D and sharpen in post if needed.
