Choppy MPEG Streamclip to ProRes 422 LT
HELP,
Doing my first edit of 7D footage, 1080p, 24fps. Bit of a nOOb, was out of the game for a while. Found out I needed to transcode the h.264 .MOV files into ProRes 422 LT. Used Compressor and it took forever! It took forever just to assign a destination for a batch of files. Installed MPEG Streamclip. Used these settings: Export to Quicktime Prores 422 LT 100% quality 23.98 frame rate Interlaced Scaling & Deinterlace Video are DESELECTED 1920x1080 unscaled Uncompressed Audio It flew through the test conversion, 75MB/sec data rate. I was stoked. So I converted like 6 hours of footage. Bad idea. I never checked the transcoded output file until just now. It's choppy. Unusable. Viewing transcoded file in quicktime. Original looks great, transcoded looks horrible. Compressor transcoded fine. Please help if you are out there, O wise wizards of editing. |
That's weird. Your settings look proper. Did the Compressor file that worked go to the same hard drive as the MPEG Streamclip ones that don't work? Ie., could the problem be a slow drive? Just a thought. Have you tried restarting? On my system after I do a bunch of processor-intensive things, sometimes I get some jerky playback in my timeline. Restart and it's cool.
Need help....
Yeap your settings looks o.k....
Try at Apple ProRes 422 without LT.... and what is your mac configuration..... |
Why are you guys doing it so difficult?
Download the EOS Movie Plugin E1 for Final Cut Pro, it works like a breeze! More info: Canon Digital Learning Center - Introducing EOS Movie Plugin-E1 for Final Cut Pro The driver download site: Canon EOS 5D Mark II Digital SLR Camera - select OS: MacOS X and then listed under software: EOS Movie Plugin-E1 for Final Cut Pro |
