The New T3i - Will digital zoom allow normal shooting without Aliasing and Moire.
The first one out there to get a T3i, I would like to see something tested.
Its my theory that if I stick a very wide lens on the camera, even shoot the wide end of the 18-55 off the T2i, and then shoot I shoot at 3 x digital zoom, I should have a better image that the same shot say without digital zoom and at 55mm setting on the zoom. It would makes sense that in the crop for that digital zoom, there should be less line skipping ?? Whose got one already ? |
Re: The New T3i - Will digital zoom allow normal shooting without Aliasing and Moir
Mine arrives tomorrow. The results I've seen from 1 test are encouraging. I will know more tomorrow night.
http://cheesycam.com/testing-3x-w-100mm-f2-8l-is-macro/ As far as I understand it, the 3x setting in the zoom feature of the camera should result in a sensor crop where close to 1920x1080 pixels are used from the center of the sensor, resulting in a relatively robust image. As you zoom in towards 10x, the image will degrade in the traditional digital zoom sense. |
Cool, Ryan, keep us posted.
That was good bloody good
very interesting
do you lose any stops of light along the way? |
First test shot will be up within the hour.
No, no light loss. Just cropping the sensor. Its like how the T3i/T2i/7D sensors are smaller than the 5D sensor, so you get a 1.6x crop factor. Now the "crop" factor is another 3x. Now, the tech behind how this works is not clear, and certainly, there aren't even enough pixels to crop the central 1920x1080 to get 3x, you'd have to go down to 1728px across. Still, its obviously that some sort of crop is occurring to provide this feature. As you zoom in beyond 3x though, you're entering no man's land where pixels are made up, resulting in a poor image. |
You can download the original exported file before web compression at Vimeo.
Thanks Ryan. Hope to see some daylight 100 ISO long distance shots.
Also would like to see a 3x of your widest lens. |
And please, a comparison of the same FOV with and without the 3Xzoom i.e frame the shot, shoot, dial in 3X zoom, move backwards to get the same frame, shoot, repeat for 5X zoom, repeat for 10X zoom (last two steps not really nescecary).
I will try to do that. Unfortunately, I work an hour from home and its dark by the time I get in. I can probably get to it Saturday. In the meantime, I expect to see more and more samples popping up all over.
I did a little test today to check for aliasing
Thanks for the test Lawrence!
What do you think the flickering is at the bottom? |
Yes, quite interesting demonstration Laurence.
Okay, can you orient us as to what was going on. On the opening shot, was that 10x digital, with the physical zoom set at wide ? ? And then 3x digital with the physical zoom at wide (18mm) ???? |
Alright, I was able to do some tests with the T3i in daylight with my 100-400mm and my 18-135mm. Everything was ISO 100 except for the last scene of the pine tree.
One shot particularly seems to demonstrate the mitigation of aliasing and moire with the 3x zoom turned on. However, noise levels appear to be slightly increased, or at least appear so. Overall, I am very, very pleased with the performance of this zoom feature when left at the 3x setting. The shots appear nearly indistinguishable from normal shots. I'm not a legit pixel peeper, but upon first pass, I feel like I now have a 3x teleconverter with no light loss. YouTube - T3i - Zoom Test Comparisons |
I just uploaded to Vimeo. Will display in standard definition, but you should be able to download the 1080p original file.
The more I look at the samples, the more I think I would admit that the 3x zoom feature is noticeably softer. However, it is still a viable image. It simply doesn't appear to resolve as much detail as normal. These tests are pretty unscientific though.
Still, download the video from Vimeo and see for yourself. I know I will definitely still use this feature. |
Ryan:
Thanks so much for taking the time to do that. I will do a bit more exploration with the footage. Chris |
really cool of you to share, thanks
great info Chris, thanks for sharing.
So on the T3i you just push the magnifying button to get the 3X zoom ? |
I downloaded Ryan's footage, and did some playing with the last scene. It is hard to tell because of the different angle of views, but I feel like the details are resolving a bit better in the 3x zoom, because of less line skipping.
However, the real way to test it is to shoot that same scene or a similar one with the lens in wide mode, at 3x, then the zoom lens set at 55mm in normal mode. In that way the field fo view should be pretty close, and which mode resolves detail better should be pretty evident. |
You pull up the "Quick Menu" and under the option to change the frame rate and size (720 60fps, 1080 24fps, etc...) there is an option to switch into 3-10x zoom mode. When activated, it defaults to 3x zoom, and then by pressing a button with the zoom buttons (same as T2i/7D) it zooms in and out at a constant rate.
I'll never use more than the 3x zoom for any serious shots. But anyways, hopefully the footage gives a glimpse. Chris, I'm definitely interested to do more tests to try out your recommendation to not move the camera and compare the 3x zoom on a wide focal length with the actual equivalent focal length with no zoom. Overall, I'm very satisfied with the T3i, even with the price bump from a T2i. Articulating screen, manual audio, 3x zoom. Its a pretty swell camera. |
Thanks Ryan, look forward to it. (I am getting that nervous stomach feeling. A BestBuy is two blocks from my house.)
I used my 4GB FAT16 Class 6 SD card which I had in my S95 so it may have been something to do with the card. Quote:
Interesting tests Ryan. I think the x3 material looks great. I'm going to head down to the camera shop today and check one out in the flesh. I'll take a card and try a few tests myself.
Good deal Mat. I know you did that piece, Hudson's Monarch. Are you thinking of using the 3x feature for macro cinematography?
I know that Emm at Cheesycam.com thought that was an excellent use for it. T3i 3x Zoom w/ 100mm F/2.8L IS Macro CheesyCam |
Very useful tests Ryan. Thanks
Been playing with it myself. Don't think it works as well as the GH2 crop but it's nice to have. Agreed stick to 3x. The rest is pointless! |
Hey Phil:
Are you saying you have been comparing T3i in 3x mode and regular GH2 footage of the same seen at similar angles of view ? If so, are you saying you can't get as good resolution as the GH2 ? |
from my VERY brief T3i testing, only got it yesterday. It doesn't seem as sharp at 3x as the GH2 does in teleextender mode. Is the Gh2 directly sampling 1920x1080?
I'm also curious about jello. Is the rolling shutter effect reduced in zoom mode?
For Phil & Ryan,
Does the zoom work in 720/60p mode? The manual seems to indicate that it's 1080p only. |
I did down load Ryan's .mov original, but he even has had to put that through render because he added titling. So I am not sure how much that render has affected things. Would be nice to test GH2 and Canon side by side to see if Canon actually gave us two camera's in one-- a 4/3's or close and an APC. Also, as I have posted in other posts, and at the Magic Lantern development web, if Canon's code is selecting an area of the chip and sampling only that, can we also possibly through a magic lantern manipulation, get the Canon only to read a letter box portion of the 16 x 9, decreasing line skipping for a 235 aperature. |
Hard enough to tell that I still find it a very worthwhile feature. |
Does the Canon 60D have this x3 zoom feature? I have chosen to buy the 60D over the 600D for other reasons but this zoom feature is nice to have.
Stelios |
No, the 60D doesn't. However, its body has a nicer feel to it, more like the 7D I hear. Also, you can manually set the white balance to a kelvin value.
It seems that Canon just keeps adding a little feature here and there is all. Some rumblings about the 5D III and an improved video codec... |
Some direct comparison tests. Download original file at Vimeo.
