60D LCD Viewfinder
Hey any recommendation for my 60d, I am getting difficult to focus on
my 60d..Thanks |
The L-Finder
The only loupe for the 60D that it not too heavy or requires a bracket.
The L-Finder FrugalFilmmakers.com |
Re: 60D LCD Viewfinder
I use the Hoodman Cinema Pro Kit. Attaches to the camera hotshoe mount in seconds and once adjusted for proper fit sits right over the LCD folded in with the screen side out.
Kit includes the loupe, 3x eyepiece, and mounting crane. I avoided this approach for about 5 months because it looked "klunky" to me but once I started using it first on the T2i, then the 7D I was amazed at how "flexible" it was. Then I got the 60D and saw that for me this was the ONLY solution. YMMV of course. Any adjustment of loupe position over the LCD going from camera to camera usually take me less than 30 seconds. Simply attaching or detaching take me about 4-6 seconds. http://www.hoodmanusa.com/products.asp?dept=1066 |
I agree with bruce i have this also, really easy, set it up then you can just take it of at ease when and needed. steve
I've have had 3 viewfinders now and this is the best:
http://cheesycam.com/ggs-dslr-3x-lcd-view-finder-loupe/ GGS. It will cut off a tiny bit of the screen in open mode unless you move your eye around but both me and my DOP love it. Trouble with the mini crane thing is you cant swivel the LCD with viewfinder, might as well get a T2i ;) I suppose it's great if you use multiple cameras but most of us just use one. |
1 Attachment(s)
The attached photo is a DIY version. The two arm support is a China product from ebay, around $50, and the magnifying lens is a $14 item from a local sewing/fabric store--cut off the handle, drill a hole and bolt to the support. This provides a very acceptable way to enlarge the LCD panel for focusing (indoors at least) . Always in focus, view with both eyes from any distance. Rotates to any position you put the 60D LCD screen in. Not so good outside unless you come up with a hood between the camera and the lens, which would not be hard to do.
Does the Hoodman HoodLoupe 3.0 fit exactly on the 60D?
stelios |
Hoodman says it's a perfect fit. I have one coming tomorrow. I also got the kit for the EX1 for focusing when the screen is swung to the side of the body, and I got a 3" lcd cover for when it's on the Blackbird stabilizer. I think I've got all the bases covered. That little screen sucks in daylight. My EX3 spoiled me.
Re: The L-Finder
