Do you use a battery grip when filming events? at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 12th, 2011, 05:48 AM   #1
Or does the increase in size \ weight not worth the increase in battery life?
Dan Burnap is offline   Reply With Quote
Old December 12th, 2011, 07:19 AM   #2
Re: Do you use a battery grip when filming events?
my 5D is on the rails all the time ,with all that stuff that comes with the setup, adding battery grip to it would be complicated, but I do use the grip for my handheld unit 60D, it makes it a bit larger and less convenient, but I like longer uninterrupted power option.
I love this place!
Old December 12th, 2011, 08:12 AM   #3
No, but I just got the AC adapter kit for the Canon 7D. It has about a 15 foot cord. I didn't get it with events in mind, but rather for those extended time lapses. A possible option for you if wall power is available and not doing handheld.
Mark
Old December 12th, 2011, 12:39 PM   #4
Not sure what you mean by events, but yes, I always shoot with a battery grip (I have a T2i). It makes the smallish T2i easier for me to hold, it obviously extends battery life, and it makes it much easier to change batteries when the camera is attached to a tripod. No major downsides IMO, although Size and weight might be more problematic on a 60D, 7D, etc.
Jon Onstot is offline   Reply With Quote
Old December 12th, 2011, 05:08 PM   #5
I haven't but I'm thinking about it when shooting handheld stuff, the Canon 550D is extremely light and sometimes i find it quite shaky. After a while my arm has stiffened up then it turns out all right. I think if I did put a battery grip on it you're adding another 400 grams or so making it about 1 kg. Which i think is a double pro if you ask me with increased battery life and steadier shots. But that's just me. Only con is, well, it's heavier on the arm! And a little bit more bulky to carry/transport.
Karl Taylor is offline   Reply With Quote
Old December 12th, 2011, 06:57 PM   #6
I just got my 60D a couple weeks ago and almost ran out of juice during a shoot. Went and got the battery grip, so no more worries with that now. However, it does add some weight, and along with the 24-105mm F4L, it became quite a heavy package. But at least I can be sure my batteries should last thru a 2 hour event.
Steve Wolla is offline   Reply With Quote
Old December 14th, 2011, 12:24 AM   #7
I have three T3i. All of them have battery grip mounted to it. Of course it doubles the battery run time which I like when filming event. It also makes T3i a little bigger and easier to hold. So it won't be so tiny that looks like a toy.
For T2i, I tested it with and without battery grip, it increases the time a little bit before the camera got overheated.
LA Color Pros Blog
Old December 31st, 2011, 03:15 AM   #8
Easier to hold the cam, easier to switch batteries on tripod, longer operational time. All true. The grip never leaves my 550D body. Good investment. Even the cheap aftermarket grips work well.
XDcamHD F330, 2" VF, Fujinon 13x3,3. 550D, MagicLantern, CS5.5
www.picturethis.tv
Eelco Romeijn is offline   Reply With Quote
Old January 1st, 2012, 10:40 AM   #9
The only issue I have found with using a battery grip is that it limits your choice of viewfinders.
You either purchase an original battergrip which then allows you to use the
EVF viewfinders, alternatively you can purchase either the Letus Hawk VF or the Hoodman Crane.
Also if you do purchase a replica is that the bottom mounting threads are only anchored into the plastic housing with no metal support behind the plastic or anything
Tariq Peter is offline   Reply With Quote
Old January 2nd, 2012, 03:23 PM   #10
I use a Manfrotto monopod with a small, halfway decent friction head. It's quick to adjust just the one pole and I clamp stuff onto the rubber shaft part - like a mike preamp and wireless receivers. It's surprising how steady this can be. Plus I can get overhead and high shots by using it like a mike boom pole. Also it's less obtrusive than running around with a tripod & head.
It makes all the difference in steadiness. And if you want to do a camera move, you sort of drag it to your next position which is far steadier than the camera alone because there is the added inertia caused by the weight and the semi-dangling monopod.
Best
Harry.
Harry Bromley-Davenport is offline   Reply With Quote
Old January 8th, 2012, 05:15 PM   #11
Don't forgete Tariq that not all non-Canon add-ons are of the same quality. I haven't bought a battery grip yet, but I've had my eyes on the Meike (been around a long time, lots of reviews available), and this page shows that the construction contains a metal plate for both top and bottom mountings:
Meike 550D Knockoff Battery Grip Review | The REX Productions Blog
Maybe I didn't fully comprehend your statement.
James Donnelly is offline   Reply With Quote
Old January 20th, 2012, 10:04 AM   #12
After posting this, I thought why not buy one and find out, I've been meaning to for a while. I paid £30 from Hong Kong with free shipping from a trader named citiwide-online-au. Really something like this shouldn't cost more than that.
After two days use, I must report that this has been an excellent purchase. The build quality and operation are superb. In no way does it feel less well made than the camera itself.
I was pleased to find out that when two batteries are inserted, it will use them simultaneously, and it's not a problem if one has less juice left. Of course you can also use just one battery, and the AA capability is brilliant to have.
The only thing the manual doesn't mention is how to interpret the in camera battery meter. Does it accurately show your percentage charge remaining across two batteries?
Overall, I think this will get left on the camera for a number of reasons. It didn't occur to me I would no longer have to remove my quick release plate to change the batteries for one. Secondly, it's un-expectedly nice to not have to contort yourself when shooting portrait.
Last but not least, I now feel like more of a pro with a battery grip. How sad am I?
Old January 25th, 2012, 11:57 PM   #13
i have 3 T2i's, and 3 grips. they almost never leave the cameras. Even if we have AC power, i like to have mobility and backup juice.
Panagiotis Raris is offline   Reply With Quote
Old January 27th, 2012, 08:23 AM   #14
James - you have a 550D or a 60D? I always had the battery grip attached to my old 10D and simply assumed that I'd want the same with my new 60D. But no, the battery consumption on the 60D is amazingly low, even having a rear screen twice as large and twice as bright as my 10D's. In a full day of shooting the 60D battery comes home half full.
So I've not bothered, even though I really like the battery grip's ability to add height and therefore enable a wrist strap to go between top of cam and bottom of grip - much nicer than having a dangly neck strap.
tom.
Old January 27th, 2012, 12:30 PM   #15
I also use a battery grip like a "quick release". I have an T3i that I mount between steadicam and slider. It turns out I always have to tweak the steadicam because I move it back and forth. Now I have a spare battery grip on both. I just need to unattached the camera off the battery grip and no need to rebalance again.
LA Color Pros Blog
Taky Cheung is offline   Reply
