Possibly "Odd" Power Supply Question
I plan on doing a bit of video production with this camera.
In general, I think I'll be happy with the on-board batteries, but I was thinking: I'll likely be mounting this camera on rails (ala: Redrock for video DSLRs ), and will have a small external monitor. I have a Gold Mount and a series of Anton Bauer Hytron and Dyonic batteries that I could put on the back of the rails to power the monitor and I thought, Can it power the camera too? If so, that would be an "all week" kind of battery setup. Does anyone know if this is a possible option? |
Here's a link to the manual and other downloads. (Maybe this link could be added to a separate sticky.)
Canon EOS 5D Mark II Digital SLR Camera According to p196, the ACK-E6 AC Adapter Kit connects an AC outlet to the camera. The kit has two parts: the AC-E6 AC Adapter (providing a DC output), and the DR-E6, the DC Coupler, which is a fake battery with a DC power cord (p210). The voltage is 8 VDC (p221). The connector from the DR-E6 looks like a typical concentric DC connector, used with many consumer electronic products. Unlike most bricks, the male plug comes from the camera, rather than the brick. BTW, I missed getting a 5D2 by a couple of hours today. Still waiting... |
Hi Guys...............
Wouldn't be suprised if there was an "off the shelf" solution knocking around somewhere, tho' not one that immediately springs to mind.
What would be usefull, well, OK, imperative, is knowing the rated output voltage from the various battery supplies and the expected input voltage to the camera, along with the expected or rated current drain. If a ready made solution isn't out there it shouldn't be too tricky to "cobble something together" to do the job, hey, it's only a series pass voltage regulator after all. I take it from Jon's post the expected camera voltage is 8 Volts, is this correct? From memory a simple series pass regulator needs about 2 volts overhead, implying a minimum battery output of 10 volts. If all the possible battery supplies satisfy that requirement then I think it's possible. Less than that and it's getting a tad more involved as we're into DC to DC converters. One possible hurdle that could trip it all up is if the camera needs that third connector from the power supply to "talk" to the on board computer. Has that DC cable with the dummy battery got two contacts or three? More? From memory none of the dummy battery units I've seen to date have used the third terminal, but that doesn't mean this one won't. CS |
Canon 5D power
Dear Mr. Roddy,
I currently make a sled mountable base for the Canon 5D which uses Anton Bauer Hytron / Dionic batteries. It will supply power for your 12 vdc accessories (lights, monitor) and the 7.2 vdc required for the camera body. Hope this is helpful. Larry lexicon.demon@gmail.com |
A DC to DC converter is almost a requirement. |
I made one using and AB mount and it has multiple variable outputs check it out here:
http://vimeo.com/2936707 x2 monitored and adjustable outputs x1 unmonitored, 2 connector, adjustable but set to 12 V outputs Outputs range from 1.2 VDC to 13.7 VDC Lemo Connectors I plan on putting an AC/DC converter in it also so that I can run off power if I want to. The box was custom built to our specs by RCI custom and they did a great job. The prices are something like this: Panel multimeters - $15 x2 Switching voltage regulators - $20 x4 Lemo female connectors - $18 x4 Lemo Male connectors - $25 x4 Anton Bauer Gold mount - $90 x1 Custom Box - $150 x1 Total cost with other misc stuff about $530 Hope it helps. schematic of how it's wired: http://www.cgllc.com/battery/ |
Would 5D MKII burn down if the voltage on the charged battery is 8.4 instead of 8.2 Volts?
I'm seeing such difference on a tester display and don't want to burn down my cam by accident T |
Consider that overclockers often juice the voltage to the RAM by 25% or more - and then run the system 24/7. The heat from a 2.5% voltage bump will be minimal. Shooting in Death Valley in the summer would be way more stressful than a small voltage bump in normal temperatures. |
But there is a maximum voltage that we don't know. Some devices heat up but other devices just pop like a fuse. There would only be one way to find out. Anyone want to donate a 5D2 to experiment on? |
