Dust internally on Kit Lens 24-105mm
Just noticed a fairly large piece of dust on one of the rear internal lens elements on the Canon Zoom Lens EF 24-105mm L IS USM after reviewing some video footage. It was noticeable when shooting the sky. Ran some tests and it presents a issue when shooting at F 8 and above. Not visible when shooting under F 8.
Has anyone had issues with this lens with dust getting inside the lens? I am wondering if the zoom extension of the front tube is pulling in any dust that may collect on it when using the zoom, when it extends out and in? Regards Steve |
Have Canon fix it, assuming you are under warranty. If you are not, I would still get it fixed, that isn't a cheapo lens.
Dan |
Hi Steve,
You need to double check maybe dust in sensor. Change another the lens and if you still see a issue, for sure your camera have dust in sensor. Cuong Dinh |
Yeah, I would definitely double check to make sure it's really the lens and not the sensor; I don't think it's common for dust in the lens to show up. If you haven't already done this, use the same body with a different lens or two at small f stops, to make sure it's not sensor dust you're seeing.
I can see a spec of something in the internal lens.
Take a test shot with a different lens. |
Dear Steve,
You may be able to get the speck of dust, in the lens, if it is actually there, to move. Sometimes you can get it to move to the side, out of the way. |
If it goes away at lower f-stop settings, it is likely not sensor dust.
How would sensor dust go out of focus when the iris changes?
"The filters on top of the sensor can be as thick as 2.5mm."
That is something I didn't know. There is a lot to learn when shifting from a video camera with integrated lens to a still camera with interchangeable lenses. |
