Firmware, ISO and Neutral Density Power
I was recently out in morning and afternoon sunlight shooting my first 25p project and wanted to try a few things. Firstly, inspired by the Zacuto Shootout I wanted to dial in an "optimal" ISO. So rather than 100 I went for 160. Secondly I wanted to stick with a 180 degree shutter speed (1/50 sec). These two things combined meant that, when compared to 1/60 sec/100 ISO setting, I had around a stop of extra light. With that extra light I found that the 8 stops of ND that I had wasn't enough to get me down to the apertures I was wanting.
Is anyone else finding that they need to go beyond 8 stops of ND? If so what are you using to get there? |
you can stack multiple nd filters if needed. Havent tested to see how many you can stack before it starts to cuase vignetting but I have stacked 2 nd filters to block upto 9 stops without issues.
FWIW, whether it vignettes depends on the lens. In general, the longer the focal length, the less likely it is to vignette. The really wide lenses have image circles that just barely cover the sensor, especially wide open.
Yes I get vignetting at the 24mm end of my 24-70 zoom even with one ND filter, (particularly if it isn't screwed on all the way).
Is title really necessary when replying?
Go to your camera menu, first tab and enable Peripheral Illumination Correction. It works for most of Canon lenses. God bless us all! Christian. |
it seems kind of irrelevant doesn't it...
Christian, thanks for your tip. I'll give it a try.
There aren't any vignetting on any of my shots with b+w nd filters.
Tested them on 24-105, 24, 85, 50 canon lenses. I did notice slight vignetting when using fader ND shooting wide open. |
