Workflow for fcp
I have fcp 7 and the new canon 5D3, and when I start log and transfer I get no info or files in the window.I dont even see the camera as a symbol on my HD?
I can however directly import the files in to fcp. They are however encoded to h264. They are that already because when I connect the camera to the computer, they show up in EOS Utility and I can then download them. On the forum I read that I need to transcode them to 422 proress for better edit and quality. Could somebody tell me if this is the workflow (H264) or do I need to transcode them? and how? Also the orignal file has a speed of 80 to 100 Mbit/s when downloaded to the computer but in fcp only between 9 and 10 Mbit/s I shot everything in 25P 1920x1080. |
Re: Workflow for fcp
Don't know exactly what your problem is, can you take the card out and use a card reader? do you have the EOS plugin loaded into FCP(S)?
Workaround is to use Mpegstreamclip (free) - transcodes perfectly to ProRes, even has a batch mode. |
Whats the file name extension show as? I've always transcoded...from what I remember you have to transcode to edit in fcp 7 and before. I'm now on fcpx.
hello ,
my problem is that i read everywhere that to edit in fcp you need to transcode to Proress. But because of the EOS UTILITY it is already encoded to H246, Extension Mov. file. I can directly import in to fcp no problem. But is the best workflow? and if so how do I go from there? as what should I export the finished edit? thanks |
I think perhaps you are confusing filetypes and codecs.
Your camera shoots in H264 codec, filetype mov FCP likes mov filetypes but not H264 codecs. Yes, you can import H264 directly into FCP but it will run very slowly, occasionally lock up, maybe crash - it is not recommended. H264 is a delivery codec not an editing codec (as far as FCP 7 is concerned anyway), the EOS Utility or Mpegstreamclip will convert from H264.mov to ProRes.mov which FCP 7 DOES like - It is the best workflow (again as far as FCP 7 is concerned). Your final edit can be exported to anything you like depending on your intended audience or medium - DVD, Web etc, it is best exported as a Self Contained movie in the ProRes format from FCP 7 - THEN converted using Compressor (which comes with FCP 7) to your delivery format. |
If you want to use log and transfer in FCP, you need to make sure you have the correct plugin installed.
Here is a link: Canon U.S.A. : Support & Drivers : EOS 5D Mark III the plugin your looking for here is: EOS MOVIE Plugin-E1 for Final Cut Pro 1.3 Without it, you'll see nothing in your F&T window. I do this all the time and it will work. MPEG Streamclip works too, but I personally don't like to batch transcode since that means everything is transfered. The ProRes files are quite a bit larger than the h264 files and you can quickly eat up a lot of disk space storing files you may not need. The great thing about file and transfer is that in forces you to go through your footage and really get to know what you have. Also you can rename your footage to make it easier to find the clip you need and loose the number files. |
thanks.I am trying compressor now but it takes a lot of time loading all the files. How does eos utility do it? I dont see any transcode options?
After installing the EOS plugin, open FCP Log and Transfer. You just transfer only the footage you want/need, or you can just drag everything over all at once. Set to transcode to file format of choice in the Log and Transfer preferences and your good to go. Works like a champ. Compressor is slow and clunky... life is too short to deal with that.
Make sure you copy the entire contents of the card from the camera (keep the directory structure intact)... don't just copy the movie files. Otherwise FCP won't recognize it. :) |
I have been doing a lot of shooting with my 5D MKII this year and decided that I needed to explore workflows for FCP 7.04. I did some pretty extensive testing and comparisons and by far the best and only utility you should be using is 5DtoRGB by Rarevision 5D to RGB Batch. It only costs $50.00 and is pretty slow but no other post workflow retains as much information from the original H264 files from the Canons. I compared it's output to Apple Compressor, the Canon I/O, MPEG Streamclip and the 5D to RGB Batch is superior to all. The only better workflow would be using Premiere Pro, FCPX or some other editing program where you don't have to transcribe the H264s to anything else.
Compressor was actually not that bad but still suffered from a loss of resolution and gamma shift. MPEG Streamclip was awful, massive amount of softening, huge gamma shift and a considerable amount of color change as well. The EOS Plug In was so so, it still puts the gamma shift into effect and it softens the image quite a bit too. For me, the 5D to RGB Batch utility is the only way to go for professional use, just make sure that you give yourself enough time to do the conversions. Fine for short form but if you have a LOAD of footage, you will spend may hours, possibly days or weeks converting it all using the 5D to RGB Batch. If I needed something faster, I would go back to Compressor. |
