Low Light Problems GL2
I've encountered low light issues in instances of virtually unlit rooms or candlelight ceremonies. I've tried a number of manual settings and am coming up drawing a blank on what to do in extreme low light. We recently purchased professional lighting to cure some of the problem but there are those who insist on keeping the light virtually too low to record anything. We did a job this last weekend where they wanted video of the crowd but did not want any lighting. Result= noise even with manual settings.
Any suggestions on how to tweak the manual settings or should we just refuse jobs where it's virtually hard to see anything even with the naked eye? |
A] Lighting
B] Gain C] Post D] Closeups using the Candles or any lighting you are allowed to use E] Hire an alternative camera with a bigger than 1/4" Chip and add this hire cost to the bill! Simple! Never turn work down - if you can avoid it? Grazie |
If better lighting is out of the question:
1. Be sure the client is aware of the limitations of shooting in poor light. Show examples to manage their expectations. 2. Once you run out of stop, try a slower shutter and live with the motion artifacts. 3. Be sure not to use high amounts of zoom that result in losing lens speed. 4. Use as much gain as you feel you can get away with. 5. Use a noise removal software in post; e.g., Neat Video. 6. Look into a camcorder that can do a bit better in low light such as the VX2100/PD170. |
Thank you
Thanks for the suggestions. I have tried the slower shutter but did have to change it back when people were dancing. I will try Neat Video first. Thanks again.
A low wattage camcorder light, maybe 10 watts, can make a difference and yet not be excessively intrusive.
Neat Video looks like it will most likely fix my issues and it's reasonably priced. $49 for home users and $99 for pro users. It's compatible with Premiere Pro and a number of other editing programs. |
And NeatVideo offers a trail version to test before you buy.
TIA, Grazie |
Neat Video Before and After Snapshots
2 Attachment(s)
Finally got Neat Video up and running. Wow, what a difference.
Hi Michelle! Thanks for remembering to post and show us the before and after - great!
Might I suggest that this shot would also benefit from some careful in-Post White Balance? Do you have the facilities to accomplish this? Grazie |
Don't forget to use a custom preset with your sharpness knocked down a few notches. This will help with noise tremendously.
1 Attachment(s)
My crude attempts at WB-ing. BTW I asked and got Michelle's agreement to do this.
Grazie |
