Which filter for sunrise or sunset ??
Which filter must I use to make some shots about the sunsire or sunset
connected to damaging the ccd's of the camera |
nd filters
for sunset you might not need anything. i have filmed a sunset before without any filters cause its already getting dark and the sun is not as bright.
for sunrise you might want to stick a nd filter on there or a Uv Filter just to be safe/ |
A graduated ND (if you're shooting land or ocean in the same frame as the sunset), this will give you richer colours and balance the exposure.
Filters
I shoot sunsets all the time, they just mesmerise me.
Nd filters as the others said. I have used a polarizing filter when I have water in the view as well. Reflected sunstes are to die by. I would definitely try them all and I would also try combinations. We have tons of color here, but if you want to enrich them further you can get half red filters and use them. |
Say Dale,
Couldn't you just do some post processing to get more color in your sunsets? As per the ND filter, what exactly does the N-D stand for? Are these standard 55mm filters? Yep, more stuff to buy $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ :( |
ND = Neutral Density . The XM2 has one built in.
Here are some great links. Exponents of filters and some technical stuff. Not too difficult either . . even I understood it. Here is a great exponent of filters at work. See/notice his little pencil sketch of how he accomplishes just what is being shown. This was a great "eye-opener" for me. Joe Cornish: http://www.leefilters.com/downloads.asp What they Do! http://www.centuryoptics.com/product...s/nd/index.htm . . and more . . http://www.tiffen.com/filters.htm . .and this is just CHOCK full of stuff .. love it!! http://www.formatt.co.uk/glass/filters.asp . .well THAT should keep you going? Grazie |
post work
David,
I have tried some work in post and to be honest, as a person who loves sunsets, all the ones i did in post did not look quite right. You can also change your red green and blue settings for more enriched effects but they do not look wuite right either. I simply just set my settings to make it look like it actually was as apposed to trying to enhance them. but then where i live great sunsets are very common occurances!!! I enjoyed the one site grazie p[osted!! out it on my list of favorites. |
Hey guys, I’ve been checking into ND filters, and other filters, for use on my GL2. I have noticed before that there is a "ND" filter button on my camera, but I thought it was a software setting, and not an actual filter. I had the idea of setting up my video camera near a beach and setting the time lapse to record the entire sunset. Has anyone come up with a setup procedure that looks pretty good? Ex: 2 sec exposure, 5 minutes apart? Also should I invest in a set of square filters and filter holder, or just get a cheaper round filter set? I like the idea of using a "Sunset" filter, but they only come in the square style.
Thanks, Dave |
you can use your built in nd filter.. you may need additional ones though depending on what you're going for
Time Delay
David,
I have tried all the time delays on my gl2 and my Sony. I could Not make any of them produce video that ran smoothly. I have found that I just set the camera on its tripod and make necessary settings. Use the lanc remote if you want to change things on the fly. I put a fresh tape in and let it run the entire sunset. Here in the northern prairies we have long sunsets and I have never run out of tape. I then go to post and use the time stretch tool to compress the frames as much as necessary to get the rate of movement I desire. I do not change the rgb settings. My normal preset is one up on the red most of the time blue and green centered. If anyone has a better way I would love to hear about, and would find it very benificial. |
