Weird offset image when panning - see screenshot
1 Attachment(s)
Hi Forum,
I have XM1 (PAL), when panning slowly I get a weird 'interlaced?' offset issue. Anybody any ideas why this is happening - when I switch the camera to 'frame' mode it is better, however the manual recommends not to use this for everything. Thanks in advance Alex |
And here it is in 'frame' mode
1 Attachment(s)
See attached for 'frame' mode version.
Alex |
Such is the nature of the interlaced beast.
Although PAL frame rate is 25 frames per second, each frame is really made up of two interlaced fields. The first field contains all the odd lines that make up the frame, the second contains all the even lines (or the other way around - depends - but the principle is the same). There are 50 fields per second. The first field is effectively a half-resolution image, as is the second but the second is "taken" 1/50 of a second later. So, if you are panning or an object is moving, you will see the effect of interlacing the two halves because they were captured by the camera 1/50 of a second apart. Frame mode doesn't show it because the whole frame - line by line - is captured in one go, every 1/25 of a second. As easy demonstration is to simply wiggle your finger in front of the lens and record in both modes. The effect of interlacing will be very apparent. You could reduce the effect somewhat by using a shutter speed that is slower than the field rate but to eliminate it entirely, use frame mode. (For NTSC, the values 29.97 and 59.94 apply instead of 25 and 50). |
Thanks John,
Maybe I am a bit simple but this seems quite daft! Do I assume that frame mode should be used whenever there is some movement (i.e. all the time as this is video...) If that is the case how comes the manual seems to think you might only want to use this occasionaly. Are there any downsides to using frame mode? Thank you for your quick reply by the way! Alex |
Have a look at the same footage on a TV. I bet you won't see the artifacts. They tend to show up on a computer monitor, because monitors are usually progressive scan. SD TV's are usually not.
For what it's worth, I always use frame mode. There's supposedly a slight drop in resolution, but I can't really see the difference. |
OK - good point.
I was starting to get depressed and everything.... Alex |
http://en.wikipedia.org/wiki/Interlace It is a perennial problem for anyone wanting to capture still images from video. Whether you choose to record frame mode or not also depends on how you will view the recording. For example, if you are going to only ever watch them after transferring to DVD and using a computer, go with frame mode since computer displays are nearly always non-interlaced these days. |
Thanks again.
So this means I have a little problem. Some footage I recently shot was not in frame mode - however I need to use this for a short clip on a web site (non interlaced). Any idea how I can 'convert it' or at least reduce the effect? Alex |
Best thing is to experiment and decide what looks best to you. |
