GL2 Playbackon ZR10 at DVinfo.net
Old May 31st, 2003, 01:20 PM   #1
GL2 Playbackon ZR10
I would prefer using my old Canon ZR-10 to playback GL2 footage to my computer. I would rather the ZR-10 take the stop and go wear and tear of video capturing and save the GL2 for recording only.
Assuming the heads are clean on the ZR-10, will there be any loss of picture quality on my final production? In other words, are the heads on the GL2 any different than the heads on a ZR-10?
Alex
Alex Geschke is offline   Reply With Quote
Old May 31st, 2003, 01:23 PM   #2
If you will be catpuring via Firewire, there will be no Loss of Quality, It is a digital signal, from the most expensive cam, to the cheapest miniDV cam... a digital signal, is a digital signal. No change.
I use a Sony TRV-17 for my playback deck. No problems
Thanx,
Tustin Larson is offline   Reply With Quote
Old May 31st, 2003, 01:27 PM   #3
Thanks.
This forum is F***ing awesome!
Old July 15th, 2004, 04:47 PM   #4
Thanks for answering the same question
I agree. This is one of the most useful sites I have found. I had the same question as the previous posting, and the answer was exactly what I needed.
Jeffrey Parker is offline   Reply With Quote
Old July 20th, 2004, 12:47 AM   #5
yep. DVi rocks! :)
Daniel Hollister is offline   Reply
