Pixel shift technology and black level at DVinfo.net
Old June 22nd, 2003, 02:09 AM   #1
Please let me know what you think.
I was looking my footage on a dlp projector.
The image looked well but specially in the black areas the color was a little bit green.
My camera is an XM1 and the image setting was on the center between red and green.
To better understand i've tried to capture some black images (closing the camera with the cover) with different camera setting and looking the result by using photoshop.
The resul was that in any cases the green level was twice of red.
What do you think about, it's problem of pixel shift technology of it's problem of camera setting?
Waiting for your reply
Giampy
Giampy Car is offline   Reply With Quote
Old June 22nd, 2003, 06:17 AM   #2
Moderator
If your image is predominantly green, sounds like your camera needs to be serviced.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old June 22nd, 2003, 09:21 AM   #3
I'm not familiar with this cam, but your problem is not related to the pixel shift technology. If there is no "black balance" setting available (like DVX100 and others have), then you need it to be serviced like Don says.
Andre De Clercq is offline   Reply With Quote
Old June 23rd, 2003, 01:04 PM   #4
Thanks for the replies.
Could it be also problem of white balancing?
I know that if you make a warm balance using for example a warm card the black goes to a green predominancies.
My second question: in whict way the camera set the white balance?
Giampy
Old June 23rd, 2003, 02:41 PM   #5
White balance sets the RGB amplification(contrast) ratio's of the highlights and should not change the black. Black balance (low light adjust) sets the ratio's of the RGB offsets (differential brightness). Today's cams perform white balancing by analysis of the image and correcting in such a way that averaged low saturation parts get equal RGB amps (in auto and manual)
Old June 23rd, 2003, 02:54 PM   #6
Moderator
Giampy,
Do you have an XL1 or the newer XL1S? Do you have the manual? You can always download the .pdf version here:
http://canondv.com/downloads/product_manuals.html
Do you know how to contact Canon Repair in your country? I would love to visit your beautiful country in the near future!
Let us know how everything is going,
- don
