Say hello to the new guy .... and of course a couple of ??? at DVinfo.net
Old August 10th, 2003, 10:43 PM   #1
Say hello to the new guy .... and of course a couple of ??? :)
Hi everybody,
Just got my GL2 this week and i gotta say that this is one mighty nice toy.
On to the questions :
Does anybody have a link or know a website that has a nice and comprehensive glossary about video terms. I'm new to this and a page that could give a hand on how and when to switch to manual control and adjust db gain, aperture and shutter speed would be of great help.
Second thing is after an hour or so of testing i got the message that the heads were dirty , tried to clean it with a DVM-12cld Sony cassette but when i rewind or forward while on playback mode i still get to see a mosaic -like image (there is even a screenshot of that in the manual to show you when the heads are dirty).
Is it normal ????
Thanks a bunch in advance for any comments/suggestions
Phil
Philippe Gosselin is offline   Reply With Quote
Old August 10th, 2003, 10:59 PM   #2
Old Boot
Hi there . . . nearly . . . .
I've only used the Sony head cleaning tape once. This is after 50 tapes, countless goings backwards and forwards while capturing into Vegas 4, reviewing on site and using cammy as VCR to TV. You've just got your GL2 AND you're getting the mosaic and the Warning too - after only say 4 hours of usage? What can I tell that you aren't thinking yourself? Maybe others will be more convincing than I???
Please tell me where and under what conditions did you purchase said GL2? Is/was it new or secondhand? Was it fresh out of the box OR a display model? . . . . . .
Good to have you, almost, onboard. . . .
Keep us informed as to progress,
Grazie
Old August 10th, 2003, 11:37 PM   #3
Thanks Graham for the reply,
Yes my friend it is brand new and out of the box. After reading your reply i decided to exchange it because this is ABSOLUTLY not normal .
Thanks again
Old August 11th, 2003, 12:22 AM   #4
Old Boot
Philippe - Understood . . .
Now, real world explanations of technical stuff:
http://www.consumerdvreviews.com/glossary/
http://www.adobe.com/support/techgui...sary/main.html
http://www.kodak.com/US/en/motion/su...glossary.shtml
DON'T forget real world experience with OUR cammies here on this Forum. Do a search. I've learnt stacks and not a little humour thrown in too!!!
Grazie
Old August 11th, 2003, 12:34 AM   #5
With any new camcorder, it's always a good idea to run a head cleaning cassette for a few seconds first thing out of the box, before you put in that first DV tape. Hope this helps,
Old August 11th, 2003, 04:47 AM   #6
Wow
Thanks a lot guys ,
Thanks for the links Graham
And Chris , i did put the cassette right after the cam told me that the heads were dirty and it still looked mosaic-like when rewinding and forwarding. The manual suggest to repeat the cleanup process up to five times if necessay , so i did but still the same results. So i guess today it is gonna be "exchange time" ;)
Thanks again
Phil
Old August 11th, 2003, 06:06 AM   #7
Seems like Canon is releasing quite a few awry GL2's these days, I've been noticing that...
Joshua Badour is offline   Reply With Quote
Old August 11th, 2003, 07:05 AM   #8
Philippe, when you exchange your camera, once you get the new one, run the head cleaning cassette one time briefly for about five seconds before putting in your first blank DV cassette. This should prevent the same problem from occuring again. Hope this helps,
Old August 11th, 2003, 07:55 AM   #9
Old Boot
errrmmmm .. .Chris . . . I didn't do that . . . . did I do something I should have? Was I lucky? Am I doing something wrong carrying on? - I've had 50 tapes[approx] gone through, used a Sony head cleaner once when the XM2 asked for it.
Respect - Grazie
Old August 12th, 2003, 12:18 PM   #10
Turns out i was just being a paranoïed freak , the camera is fine . The mosaic-like that i was experiencing was when i was rewinding and forwarding while on playback mode , turns out this is normal.
Thanks for all your input.
Phil
Old August 12th, 2003, 12:43 PM   #11
Old Boot
. . . er yes . . that's correct . . .
Old August 12th, 2003, 01:14 PM   #12
Well if I made you laugh that's at least that ;)
Old August 12th, 2003, 03:28 PM   #13
Old Boot
I aint larfin' ! It was just a new one - that I didn't see coming . . .
Regards,
Grazie
Graham Bernard is offline   Reply
