Go Back   The Digital Video Information Network > Standard Definition (DV) Acquisition > Canon GL2 / GL1 Son of Watchdog
And PAL versions XM2 & XM1 plus Canon Optura series camcorders.
Old September 25th, 2008, 02:35 PM   #1
Help with getting sound to camera
We are in the processing of taping with a canon gl2 camera and would like to pull sound from a macee 32 channel sound board. We used an audio-out from the sound board using an xlr to an rca plug into the camera, but my sound level did not change. I put the rca plug into the a/v plug in the back right side of the camera. I am a new user to the camera, so any suggestions would be appreicated.
Barry Edmundson is offline   Reply With Quote
Old September 25th, 2008, 05:37 PM   #2
Try running an RCA line out from the mackie into the 1/8" mic input (towards the front on the right side of the GL2) Turn the mic attenuation on in the GL2 to keep from getting too hot of a signal, then set and check your levels at the camera, monitoring through a pair of headphones plugged into the camera.
I've used this configuration many times and have been very pleased with the results.
Frank Simpson is online now   Reply With Quote
Old September 27th, 2008, 04:18 PM   #3
mic attenuation on canon GL2
I tried to turn the mic attenuation on in the GL2 but had no success. If I can get this part done, we will try your suggestion in the morning. Hope you can message me through this.
Old September 27th, 2008, 06:04 PM   #4
Just remember that a line-level signal is pretty hot, so you'll need to set your audio levels manually and start low and bring them up to where you need them.
Old October 26th, 2008, 04:00 PM   #5
I've done a couple of school projects with my kid using some decent condensor mics hooked up to my Behringer 802 mini-mixer with really good quality on the sound.
Main outs of the mixer ran to the mic in port on the GL2 using a RadioShack dual-RCA to 1/8" stereo plug. Works GREAT.
Tim OBrien is offline   Reply With Quote
Old October 26th, 2008, 05:38 PM   #6
When using the mic jack as an input, it is usually best to set the mixer output to MIC level. That avoids the possibility of clipping in the first preamp stage.
dpalomaki@cox.net
Don Palomaki is offline   Reply
  You are here: The Digital Video Information Network > Standard Definition (DV) Acquisition > Canon GL2 / GL1 Son of Watchdog
Google
