Dropped, Battery Case, Cracked it - DIY - Repair? at DVinfo.net
Old September 14th, 2003, 04:47 PM   #1
Old Boot
Title says it all! Any thoughts? - Battery still functions. Just a crack along one edge.
ANy DIY solutions? Glue, Gaffa tape, Super Glue, Epoxy resins - SPIT!
Grazie
Old September 14th, 2003, 08:23 PM   #2
Use some CA (cyanoacrylate glue) available at hobby shops everywhere- they have various grades from thin to gap filing thick formulas- use whatever works for that crack- to speed drying- get some accelerator while you're there! Trust me CA is super glue in it's truest form! It wont break there again.
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old September 15th, 2003, 12:13 AM   #3
Old Boot
Steve, excellent! So CA or SG is the way to go? - I don't know of an accelerator or cyanoacrylate glue here in the UK - we do have Super Glue though. The crack is quite clean, and runs along the "slide" groove. Will the SG effect anything inside the battery pack itself?
Grazie
Old September 15th, 2003, 03:23 AM   #4
We (the Aussies) use 5 minute areldite. It's excellent for things like this, it dries clear and works out to be harder than the plastic on the battery pack.
I have found glues like super glue tend to crack under certain stresses associated with heat and or mostiure.
Jack
Jack Robertson is offline   Reply With Quote
Old September 15th, 2003, 03:38 AM   #5
I probably would try epoxy, but more to the point, check to be sure the battery takes and holds a charge. Be around when it first recharges to be sure it does not heat out of control. And be sure you have a good supply of spares. The fall may have shortened its life significantly.
dpalomaki@dspalomaki.com
Old September 15th, 2003, 03:52 AM   #6
Old Boot
Good points, Jack & Don. I'll take heed of your sound advice. I'm getting to the point where I might just ditch the battery in the correct manner and obtain a replacement.
A salutory experience . . .mmmmm .. .
Grazie
Old September 15th, 2003, 04:07 AM   #7
Graham,
I wouldn't throw the battery out unless I tried it first. It may well be working perfectly. When you first charge it, monitor the heat... if it heats up too hot it may have a problem, if it doesn't heat up unusually, just use it and see how long it lasts in your camera, if it seems normal, then it is likely to be fine.
Jack
Old September 15th, 2003, 05:50 AM   #8
Warden
The effects of dropping your battery may not be readily apparent for days, weeks or even months. The damage my be minor, such as reduced life or overall performance and discharge times. However, a drop severe enough to crack the case could cause severe internal damage. Even charging the battery risks damage to your charger. The battery could severely damage your camera. Internal components could be damaged (cracked) and yet not fail for several months. My advice is to dispose of the battery properly.
Jeff Donald
Carpe Diem
Old September 15th, 2003, 08:46 AM   #9
If it's a thin crack and clean- i'd go to the hobby shop and use "thin" CA and accelerator (kicker)......I can almost gurantee it will work perfectly and never break there again!! Takes all of 1 minute to implement the fix.
www.stevenunez.com
