SD card vs MM card for GL2 at DVinfo.net
Old November 2nd, 2003, 05:59 PM   #1
Help! can someone tell me more about using the SD and/or MM cards. Is one better than the other? My manual listed a 64mb card and did not list a higher MB card(128)? that can be used. Or dod i even need a larger card?
I had 6 photos on a 8mb card using fine. Should I get more if so what did I do wrong? I know I can use the other mode to gain more photos. But the photos on fine are great. Thanks for any help I get.............Steve
Steve Olds is offline   Reply With Quote
Old November 3rd, 2003, 12:12 AM   #2
My understanding is that they're pretty much the same, except an SD card has a lockable slide switch on the side which provides the option of securing the data against a re-write. SD cards are available up to 1 GB now, I believe.
Old November 3rd, 2003, 01:09 AM   #3
Thanks! I found a 32mb for $20.00 think I will buy it and start shooting.
