Century Optics 16:9 Widescreen Adapter - Page 5 at DVinfo.net
Old December 5th, 2007, 07:49 AM   #61
I believe there was a Sony mount version listed on the site yesterday.
dpalomaki@dspalomaki.com
Old December 5th, 2007, 11:10 AM   #62
Sponsor: Schneider Optics
Originally Posted by Simon Ash View Post
Would this be suitable for the Sony PD170?
Cheers
Simon
Yes. Here is the link.
http://www.schneideroptics.com/Ecomm...D=1072&IID=873
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old December 10th, 2007, 10:39 AM   #63
Can someone explain to my stupid little brain what the difference between this and a standard wide angle adaptor is? Does it make any 4:3 camera natively 16:9?
I can't get my head round the idea.
Dave Robinson is offline   Reply With Quote
Old December 10th, 2007, 11:36 AM   #64
Yes. That's exactly what it does, except remove the word "native." The camera is still native 4:3, but with this converter it's now recording 16:9 anamorphic without losing any vertical resolution.
This is completely different from a standard wide angle adapter, which simply gives you a wider field of view and has nothing to do with the aspect ratio of the image itself (in other words, a wide angle adapter used on a 4:3 camcorder is still giving you 4:3 video).
Old December 10th, 2007, 11:38 AM   #65
It's pretty simple really... :
the WA lense will give you just that : a wider angle either in 4/3 or 16/9
the 16/9 adaptor here will actually make sure that you use all the pixel of the 4/3 normal ratio of the GL2 for a "real" *optical* 16/9 ratio, instead of using the mode "widescreen" on your GL2 which give you a "false" 16/9 ratio, electronically created...(which is losing resolution)
In short, this adaptor will give you more resolution (the maximum that the GL2 can) if you want to shoot in 16/9.
It's basically the best way to get the best 16/9 from a GL2 (or any 4/3 cameras for that matter). Other than that, you need to get a camera with real 16/9 chips (XL2 for instance or almost all HD camera around).
Phil
Philippe Messier is offline   Reply With Quote
Old December 10th, 2007, 04:01 PM   #66
Full vertical resolution, but wider pixels, so horizontal width is greater for the same number of pixels. Also,apparently it is not full zoom-though on either end, but you do get a bit wider horizontal field of view than you do with the standard lens at full wide.
Old December 11th, 2007, 08:12 AM   #67
Is there an XL1 version somewhere?
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old December 11th, 2007, 11:20 AM   #68
I've not heard of a 16x9 adapter with 72mm mount specifically for the XL1. Panasonic offers the Anamorphic Adapter LA-7200G in 72mm mount for some of their camcorders. But I really know nothing about it. Some details and reviews at:
http://www.bhphotovideo.com/c/produc...s_Adapter.html
I understand it has been tried on a XL-series camcorder, but have no personal experience with it. You may find more information in the several XL series camcorder forums.
For the price you would have to pay for a quality 16x9adapter in a 72mm mount, and considering the limitations it may have on zoom range, etc., you just may be better off trading the XL1 and cash for, say, a XH-A1 with native 16x9 capability, and HD to boot. Then again, you may be able to find a used model at a bargain price from someone who has switched to HD.
Old December 11th, 2007, 11:31 AM   #69
My question was mostly asked in relation with this sale from schneider optics. I never considered a 16:9 adaptor an option because of the limitations you pointed and the relatively high cost usually asked for them. Instead I bought an XL2.
But I have an XL1 sitting on a shelf here and if there was an adapter for a couple of hundreds or less, I might be able to use it in some two cameras situations.
Old December 11th, 2007, 01:40 PM   #70
I see them listed used for around U$400, give or take, on auction sites, Craigs List, etc.
Old December 11th, 2007, 10:39 PM   #71
Good evening,
thankyou for this post. I eyeballed these a couple years back for my gl2 and passed because of the expense. I ordered mine today.
Ishoot 2 camera shoots with an xl2 and a gl2. Truly a score!!!!
thanks again!!! especially to schnider optics!!
DATS ALL FOLKS
Dale W. Guthormsen
Old December 12th, 2007, 05:11 PM   #72
so, do you have the camera set on 4:3 or 16:9
Travis Halverson is offline   Reply With Quote
Old December 12th, 2007, 05:26 PM   #73
When using the Century 16:9 adaptor....set the camera for 4:3.
You expand the video to 16:9 after capture.
Bob T.
Bob T.
Old December 12th, 2007, 06:11 PM   #74
I ordered this to compliment my VX. I know it is bayonet for that camera. I am curious if I could use it on my HV20 to get academy or wider aperature, with some sort of adapter. Might be fun to play with...
Chris J. Barcellos
Old December 13th, 2007, 05:47 PM   #75
This seems to be just what I am looking for. YES !! I have two GL2 cams. However, would you please answer some questions?
Can we say that this lens will give me a true anamorphic picture? I think the answer is "YES". If so, how will I "unsqueeze " the picture when I capture it using Premiere Elements? It's OK if I don't,or don't need to, but my main concern is if I burn the final editied project to a DVD will it be in an anamorphic 16:9 format on the disc?
In other words will a DVD player set in the 4:3 mode properly display the geometry of my film with black bars at the top and bottom of the screen? Yet if the DVD player is set in the 16:9 mode, will the picture have correct geometry and fill the widescreen TV ???
Tom Blizzard is offline   Reply
