Accidently Mixed Tapes, now camera ruined, help! at DVinfo.net
Old January 20th, 2004, 09:05 PM   #1
Ok my little brother stuck maxell tapes in my GL2, I always use sony premiums. I did a test on a sony premium and it looks like the heads are ruined (big square blotches randomly flash sometimes)
Is this fixable?
Lyndon Golanowski is offline   Reply With Quote
Old January 20th, 2004, 09:13 PM   #2
Retired DV Info Net Almunus
Get a head cleaning tape and use it as directed on the tape's instructions. Repeat once if necessary. This should get you back in shape.
If not, you'll have to send the camera to Canon for head cleaning.
Old January 20th, 2004, 09:25 PM   #3
What's the best way to know they it is clean for sure? If I run a half hour recording and no blotches pop up should I be in the safe zone?
Is it ok to use any cleaning tape? and then go back to sony premiums or will that cause a chemical reaction between the cleaner and the tape?
Old January 20th, 2004, 09:29 PM   #4
Outer Circle
A Sony cleaner should do.
How would you know? You'll know. :-))
http://www.dvfreak.com/tape.htm
Frank Granovski is offline   Reply
