Remote Control at DVinfo.net
Old February 16th, 2004, 01:39 PM   #1
Remote Control
I've changed the batteries and checked the remote set code, but I still can't my remote to work. It was working intermittently earlier in the day, but just stopped, which would indicate a battery problem. I still couldn't get it to work with new batteries.
Is there a setting other than the Remote Set code that I could have inadvertantly changed that would prevent the remote from working?
Phil von Kamecke is offline   Reply With Quote
Old February 16th, 2004, 02:43 PM   #2
Make sure your shoulder strap isn't blocking the IR receiver. If it was working intermittently and you didn't change any settings, they aren't the problem.
Evan Kubota is offline   Reply With Quote
Old February 16th, 2004, 03:30 PM   #3
Thanks Evan! That was it!!
phil
