auto-shut off fix at DVinfo.net
Old February 25th, 2004, 05:00 PM   #1
auto-shut off fix
Has anyone found a way around the automatic GL1 shutoff in camera mode? I would like to record with a different deck (VIA S-video or firewire) that would be able to capture a lot more than one hour of quality footage.
The best work around I can come up for this is to record with a tape in the camera. When the tape runs out then just rewind it. Hit record and record over what was just shot.
I would like to find a better way as to not put extra wear on my heads. Plus the rewinding and hitting record will take away from what is being recorded.
Jeremy Stadnika is offline   Reply With Quote
Old February 25th, 2004, 05:48 PM   #2
I had the same problem and since I just wanted the video out via firewire and not capture to tape I found that when the tape is fast forward to the end and left that way the camera would not turn off. Strange I know but it works.
Hart Boyd is offline   Reply With Quote
Old February 26th, 2004, 01:01 AM   #3
See the article Standby Mode Explained. It was written for the XL1 but equally applies to the GL1. Hope this helps,
Old February 26th, 2004, 05:17 PM   #4
Thanks a lot guys.
