canon gl2 to preview at DVinfo.net
Old February 25th, 2004, 05:30 PM   #1
I want to set up my GL2 to my computer. then use a tv as an external monitor. I use vegas 4 to edit which supports this. I know how to hook it up but what settings do I use for digital to analog (tv) I found the set up for analog to digital.
Henry
Henry Fusco is offline   Reply With Quote
Old February 26th, 2004, 12:01 AM   #2
Old Boot
Henry - I too use VEgas 4. I'm having a real problem understanding your question - better, would you explain what you are trying to eventually achieve?
"I want to set up my GL2 to my computer. then use a tv as an external monitor." Understood!
"I use vegas 4 to edit which supports this." Yes it does and yes you have . . "I know how to hook it up"
" . . .but what settings do I use for digital to analog (tv) .. . " Editing or {Previewing or Capturing or Printing to Tape?
" .. I found the set up for analog to digital." . . . I don't understand.
Look:
Capturing: Plug in Cammie Vegas recognises it
Editing: Preview hit the TV Icon in the Toolbar above the Preview window.
PTT - if this is at the core of your enquiry: You can:
1 - PTT from timeline EITHER a)Manual b)Device Control
2 - PTT from vidcap
In both these scenarios your Camie will be picked-up through the Windows Camcorder Driver .. . it's really straight forward . .what is NOT happenning for you?
Best regards,
Grazie
Old February 26th, 2004, 05:46 AM   #3
RED Code Chef
Keep in mind that if you want to use your GL2 to see the output
on a monitor you must put your GL2 in VCR mode. Then hit the
TV icon as Graham described.
Rob Lohman, visuar@iname.com
Old February 27th, 2004, 08:16 AM   #4
"what settings do I use for digital to analog (tv) I found the set up for analog to digital."
Whell, if you found the set up for A to D, disable it and it will work the other way: D to A.
Cosmin Rotaru
Cosmin Rotaru is offline   Reply
