Go Back   The Digital Video Information Network > Standard Definition (DV) Acquisition > Canon GL2 / GL1 Son of Watchdog
And PAL versions XM2 & XM1 plus Canon Optura series camcorders.
Old June 30th, 2009, 10:03 PM   #1
Dubbing problem with GL-2
Hi, I taped some footage with my GL-2, then put it in my canon zr 900 and transferred it to my GL-2, so I had two tapes. The tape that I transferred will not play in the zr 900. The error messages said incorrect tape specification. Canon tech support told me some camcorders are not always compatiable with other camcorders. I know they are wrong because a mini dv tape will play in any mini dv camcorder. She also said that if I record in movie mode that the fps will be different so that will happen. I recorded it in normal mode.
Does anyone know what could cause that problem?
Tony
Tony Marino is offline   Reply With Quote
Old July 1st, 2009, 09:14 AM   #2
Did you check to make sure the tape plays ok in the GL2? Myb the connection wasn't right & the tape is blank or some kind of static.
David Barnett is offline   Reply With Quote
Old July 1st, 2009, 01:20 PM   #3
Yes, the tape plays fine in the GL-2. I can try it again, but I'm curious as to why it happened.
Old July 4th, 2009, 05:46 AM   #4
SP or LP speed?
How long ago was tape you copied shot?
Was the suspect tape used previously in another machine?
Subtle changes in tape path alignment can cause playback issues when a tape is taken to another machine.
Have you tried making a copy in the other direction, from the GL2 to the ZR900?
dpalomaki@cox.net
Don Palomaki is offline   Reply
  You are here: The Digital Video Information Network > Standard Definition (DV) Acquisition > Canon GL2 / GL1 Son of Watchdog
Google
