Attaching a mic AND light to a GL2 . . . at DVinfo.net
Old March 31st, 2004, 10:55 PM   #1
Does anyone know of a way to have a DM-50 AND a light, or for that matter, any direction mic AND a light attached to a GL2's hotshoe? Is there some accessory that will allow this? Or at least an accessory that will allow you to attach both a mic and light to the camera, even if they have to be self-powered.
I have a DM-50 currently, and I don't know how I'd use it AND a light with one of my GL2's.
Black Label Films
www.blacklabelweddingfilms.com
Travis Cossel is offline   Reply With Quote
Old March 31st, 2004, 11:10 PM   #2
Travis,
I found something on a UK website (sure you can find something similar over the pond).
I found it at www.keene.co.uk
Have a look at the "Products" then "Supports" page the Accessories,Shoes, brackets, mounts supports. The item is last on the list (Twinshoe), this will be OK as long as you have a light that does not need the Cam power (or Mic).
ps I do not have it but have thought about the idea.
Alan McC
Alan McCormick is offline   Reply With Quote
Old March 31st, 2004, 11:17 PM   #3
I can't get that website to load right now, but I'll check it out again later. Thanks.
Black Label Films
Old April 1st, 2004, 03:02 AM   #4
Old Boot
B&H good place to start looking in USA .. .
. . here's some "gizmos" . . .relatively cheap .. .
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=146293&is=REG
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=114983&is=REG
Grazie
Old April 1st, 2004, 09:59 AM   #5
Thanks for the links. Unfortunately, those accessories won't work with the DM-50, which requires access to the hot-shoe power source on the GL2. Guess I might need to look at getting a self-powered shotgun mic eventually.
Black Label Films
Old April 1st, 2004, 10:04 AM   #6
I looked around a bit for the same thing, and had little luck. I ended up getting a different mic and light. I also got a tri-mount from NRG (via Zotz) that holds it all, plus an extra shoe mount for wireless receiver etc.
It's not a bug, it's a feature.
James Sudik is offline   Reply With Quote
Old April 1st, 2004, 11:26 AM   #7
I'm curious, what light did you get, how happy are you with it, and what type of film jobs do you typically use the light on?
Black Label Films
Old April 1st, 2004, 01:25 PM   #8
The Canon VL10li. It uses a 900 series battery, which is why I picked it up. No cords, no power supply issues. It is a decent little light, puts a lot of light in front of the cam. I have only used it in amatuer situations, and it seems like higher end consumer stuff, not pro. But for lighting up interviews or receptions, I think it would be fine. That is my intended use for it. Here is a link to it on the Zotz website.
http://www.zotzdigital.com/?page=shop/flypage&product_id=85&category_id=4e12a84308299d077092e7301ca32370
Sorry, just copy & paste it for now, I'll read up on how to post a actual link soon :)
Old April 1st, 2004, 04:38 PM   #9
I've been trying to avoid using a camera-mounted light because I've heard it can annoy/distract people at wedding receptions What are you thoughts on that? Have you aimed the camera at yourself to see how bright the light is?
I'm just concerned because it's hard enough to get people to open up and talk to the camera at receptions, and having a light in their face would seem to make that more difficult. What do you think?
Black Label Films
Old April 1st, 2004, 05:44 PM   #10
Good point, and I am no wealth of info here. It is a bright little light, and spot-on into the face would be too much I think. There are alot of options though, since it is highly mobile/moveable, and only around $75. It seems that you would have to have a camera-mounted or hand-held light to wander around a reception etc. This would fill that bill, but I am sure there are better (if more expensive) options. The tri-mount I am using can put the light really "tall" over the camera (which helps some I think), and I am considering some type of gel and/or deflector to soften it up and avoid blinding people. I know that this light is in use by people here, hopefully they will comment. Have you searched the forums with the light as a keyword?
Old April 1st, 2004, 08:20 PM   #11
Nope haven't done that yet. It hasn't been a priority for me yet. But with summer and quite a few high-end weddings approaching, I'm starting to wonder more if having a light would be a good thing.
Black Label Films
