Poormans shotgun mike? at DVinfo.net
Old April 2nd, 2004, 12:30 PM   #1
Has anyone tried modifying the internal mic to change it's pick-up pattern? Maybe a tube attachment of some kind, to block sounds coming from the sides and rear?
Ming Dong is offline   Reply With Quote
Old April 2nd, 2004, 01:18 PM   #2
Retired DV Info Net Almunus
Unfortunately, it's not that simple. For starters, the GL2's onboard mic is actually two mics configured for stereo. But even if you disabled one side it would not leave you with a directional mic. The electronics and physical design are quite different. (And, no, sticking a tube on the mic won't work, either.)
There are several good, relatively inexpensive directional mics available. Poke around in the audio forum and online.
Ken Tanaka is offline   Reply
