Analog > Digital via XM2 - problems at DVinfo.net
Old May 9th, 2004, 03:05 PM   #1
Woodyfang
hi all.
I'm trying to capture footage from VHS to my computer via my XM2
I've done just as the manual says:
plug scart output from VHS player to S-Video socket on camera (the manual assures me that both composite socket & S-video socket can be used as video inputs)
with the camera in record pause I should be able to see the image from the playing VHS on my LCD screen, but it is black.
Have just tested cable by plugging S-Video into socket on my computer graphics card, & scart of TV, picture comes thru fine, the scart end has all the pins.
this is the first time I've tried this. Anyone have any ideas?
cheers
Hagop
10 films online http://www.undeadarmy.org
STOP PRESS!! http://www.honeyweasel.com STOP PRESS!!
Lighting Cameraman / Director / Producer / Music Producer / DJ / Web Designer / Visualist / Media Student / IT Tutor / Digital Artist
W00dy See, W00dy d00...
Hagop Matossian is offline   Reply With Quote
Old May 11th, 2004, 03:38 AM   #2
Woodyfang
screwing! it works fine on my mums DCR-TRV22! What the hell is wrong with my XM-2?
Old May 11th, 2004, 05:40 AM   #3
You forgot to tell us if you activated "anolg in ->DV" (or smthng like that) in canon's menu.
Cosmin Rotaru
Cosmin Rotaru is offline   Reply With Quote
Old May 12th, 2004, 03:23 AM   #4
SCART connexion bidirectional
Sorry my english is very bad. If you use the SCART connection included in the Canon pack you never can convert analog video to digital video. THE SCART CONNECTION IS UNIDIRECTIONAL.
YOU MUST BY A BIDIRECTIONAL (IN/OUT) SCART CONNECTION.
I had the same problem and I solve it buying a BIDIRECTIONAL SCART CONNECTION.
SCART CONNECTION = Euroconnector in Europe I believe.
Pepe Garcia is offline   Reply
