Question about the Canon WD-58H lens at DVinfo.net
Old June 2nd, 2004, 12:45 PM   #1
Is this lens compatible with Canon G series digital Cameras?
I know they make a W-DC58N wide angle lens for the G3, but it IS 58mm thread size on both lens.
And also would the teleconverter I have for my G3 (Canon T-DC58N) work with the GL2? Again it has 58mm thread size.
Toogood Studios
Jeff Toogood is offline   Reply With Quote
Old June 4th, 2004, 03:49 AM   #2
Well, I do not own a Canon G3, but if both cameras have a 58 mm thread my guess is that the converters can be used on both cameras.
But the WD-58H is a pretty big and heavy converter so I would be carefull screwing it on your G3, could that lens hold the weight?
Hopefully I could have been of any help
Joris Beverloo is offline   Reply With Quote
Old June 4th, 2004, 04:53 AM   #3
I have a Raynox MX-3000PRO for my XM2 and I have tried to attach it to my SLR camera, Canon EOS 50, on top of the 28-80mm lens.
It doesnīt work. It wont focus. I suppose that this can be because the semi-fishey onle works on my XM2 at the widest zoom.
I donīt know about other lenses that support a wider zoomrange.
Viktor Carlquist is offline   Reply With Quote
Old June 4th, 2004, 06:27 AM   #4
Well I tried my G3 teleconverter on my GL2 and it doesn't work. The GL2 can't focus through it.
So I guess there are different models for a reason :)
Toogood Studios
Old June 4th, 2004, 06:27 PM   #5
viktor how much did you pay for your raynox and how does it compare to the death?
peace
Yohann Kouam is offline   Reply With Quote
Old June 7th, 2004, 01:32 AM   #6
I paid about $200 US at todays exchange rate. It works great and the distortion is very low.
I donīt have anything to compare with though.
Its a semi fisheye at 0.3x and it doesnīt support zooming at all. Only focuses at maximum zoom.
Im thinking of getting a 0.6x Raynox as wll. This one would support full zoom.
The Raynox converters are in my opinion a lot of lens for the $$$
Old June 7th, 2004, 05:18 AM   #7
Capt. Quirk
Jeff- From what I have gathered, still camera lenses won't usually work for video.
www.SmokeWagonLeather.us
K. Forman is offline   Reply
