GL2 and iPhoto at DVinfo.net
Old July 23rd, 2002, 03:53 PM   #1
GL2 and iPhoto
Will the GL2 work with iPhoto out of the box, or do I have to install the Canon DIGITAL VIDEO SOLUTION DISK?
Steve Garfield is offline   Reply With Quote
Old July 23rd, 2002, 05:02 PM   #2
Warden
This question is being asked all over the web (iPhoto support of camcorders) and the answers presently is a qualified no. It appears not to recognize any FireWire cameras, still or video, at this time. I'm sure future upgrade will address this. In most case the storage card (smart media, compact flash, memory stick, secure media, etc.) can be read by an external reader. Apple's site has a list of compatible cameras and card readers http://www.apple.com/iphoto/compatibility/
Jeff
Old July 23rd, 2002, 06:20 PM   #3
The GL2 has a USB connection
Thanks.
That was a great reply with a nice link over to Apple.
The GL2 has a USB interface too, in addition to Firewire.
You'd think that it would be supported by iPhoto like all their digital still cameras.
Old July 23rd, 2002, 07:01 PM   #4
You can get a cheapo card reader for your mac w/ either usb or fwire interface that'll work great w/ iPhoto. I got one for my camera and leave it plugged in cause I was sick of plugging cables in and out of my camera to dload.
Food for thought.
-- Schwa
Joshua Wachs is offline   Reply With Quote
Old July 24th, 2002, 06:26 AM   #5
Getting Still Images from the GL2 to a Mac running OS X
The Canon GL2 has a USB cable which allows you to directly connect the camera to the Mac.
Canon includes some software that allows you to view the images you have on the camera before downloading, and the ability to print out in a number of ways.
For anyone who's interested, here's how you can connect a GL2 to a Mac running OS X without using the Canon software:
How to Get Still Images from your Canon GL2 onto a Macintosh with OS X
1. Connect power adapter to camcorder
2. Connect camcorder to mac with usb cable
3. Slide power switch to play
4. Slide tape/card to card
Canon_dv is mounted on the desktop with three folders:
DCIM
MISC
TITLE
Mac OS X sees the camera and puts up a dialog:
Download to: Pictueres, Movies, Music
Automatic Task: None, build web page, format
Hot plug action: Image Capture application
Items to download
Old July 24th, 2002, 06:31 AM   #6
cont.
Download some/Download all
Click download all and your pictures go into your pictures folder.
To finish
1. Drag Cannon_DV icon to trash
2. Turn off camcorder
3. Detach USB Cable
Old July 24th, 2002, 08:06 AM   #7
That's actually good news. Run iPhoto and it should ask you if you want to dload to it by default.
Then that other app won't load.
Old July 24th, 2002, 09:15 AM   #8
iPhoto Rules!
Cool.
I told iPhoto to open up when a camera is attached and it opened when I attached my GL2 in CARD mode.
Imported the pics.
No problem.
--Steve
Old July 25th, 2002, 06:26 PM   #9
GL2 with OS9
BTW, on my Pismo Powerbook, the GL2 appears as a disk icon when connected. You get the same folders as in OSX. No software required.
As an additional FUN note. I've been able to copy 640x480 JPEG images TO the camera for copying to tape -- My company logo and copyright info for one. Kewl stuff. (You have to name the file correctly for it to be recognised, "AUT_0001.JPG" for instance.
Michael
Michael Westphal is offline   Reply With Quote
Old July 25th, 2002, 07:48 PM   #10
Great tip Michael.
Also with OS X and iPhoto, since iPhoto's import is rather limited - all or nothing - opening that disk and dragging the images you want into the iPhoto window is a much nicer way to import.
-- Schwa
