Difference betweeen fine and standard? at DVinfo.net
Old August 6th, 2004, 01:33 AM   #1
I was taking some stills with my XM-2 when I started to wonder what the real difference between fine and standard quality are. Is it worth using fine over standard all the time?
www.ninjafury.com | www.ronniegrahn.com
Ronnie Grahn is offline   Reply With Quote
Old August 6th, 2004, 06:24 AM   #2
RED Code Chef
Personally I always go with the best quality a photo camera has
to offer (which includes the options on a video camera like this).
If you can't store enough photos get a bigger card, they are very
cheap these days and a 128 or 256 MB card should allow you
to store enough photos for a one day shoot easily.
Fine just uses less compression, so file sizes will be better, quality
will increase and compression artifacts will decrease.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
