Matching GL1's to GL2 at DVinfo.net
Old October 13th, 2004, 09:43 AM   #1
I use two GL1's and a GL2 for weddings. What settings are other people using to better match the image of the GL2 to the GL1's, or vice versa?
I use the GL2 in the balcony and the GL1's as front cameras. Even though I moved the color phase toward green, it does not match the GL1's very well.
Also, 1 of the GL1's appears to have too much saturation compared to the other GL1.
Mike Donley
Mike Donley is offline   Reply
