GL2 / XM2 Frame mode - Page 19 at DVinfo.net
Old May 13th, 2004, 05:57 PM   #271
Retired DV Info Net Almunus
Welcome Bryan,
In all modes, 1/60 is your native shutter speed for NTSC. That is, video will generally look best if you can shoot at that shutter speed. In fact it's not a bad idea just to assume that shutter speed is unchangeable from that number.
Old May 26th, 2004, 12:26 AM   #272
"However, if you’re locked off and the tripod is on an unsteady surface like a press platform or there is vibration from wind, etc., image stabilization can be very helpful."
from www.alanbarker.com
Prech Marton is offline   Reply With Quote
Old May 26th, 2004, 06:35 AM   #273
doesn't panasonic use a OIS&EIS combination?
Cosmin Rotaru
Cosmin Rotaru is offline   Reply With Quote
Old June 30th, 2004, 09:16 AM   #274
Disadvantages to Frame Movie Mode?
Are there any?
Jason Gurwin is offline   Reply With Quote
Old June 30th, 2004, 10:19 AM   #275
There is a slight degradation of picture quality. You can test this for yourself by coupling the camera to a TV monitor and try switching from frame to normal. It can be quite acceptable however.
Here's a sequence I shot yesterday in frame mode with the Title Mix letterbox function enabled.
It's a big file, so you need ADSL ;-)
http://robindr.neptune.com?selectedalbum=robindr54027
Robin
Old June 30th, 2004, 11:49 AM   #276
Very pretty video, Robin. Reminds me of my trips to Ireland. I'm jealous that you folks in the British Isles have so many "scenic vistas" at your disposal!
Jim OMalley is offline   Reply With Quote
Old June 30th, 2004, 11:57 AM   #277
You loose 25% of vertical resolution when using frame mode (horizontal resolution remain the same). But many folks, including me, prefer this softer look.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old June 30th, 2004, 12:22 PM   #278
Jason,
Jason
The 25% resolution mentioned above, is accurate, and also overstated.There's a pretty good discussion of frame mode here (I should know, I wrote it):
http://www.dvinfo.net/conf/showthrea...threadid=27777
skip down to the bottom of the first page, and onto the second for the skinny on frame mode...or do a search on all of dvinfo...as this has been a hot topic for years....lots of discussion.
Barry
Barry Goyette is offline   Reply With Quote
Old July 1st, 2004, 10:03 PM   #279
I just got my GL2 this week, and in my (thusfar limited) tests, Frame Mode has produced some noticably "jittery" video. Especially when panning, one can almost see the picture "jumping" between frames. Is this normal? Is there some setting I can change to smooth this out?
Joe Kave is offline   Reply With Quote
Old July 1st, 2004, 10:44 PM   #280
Congratulations on your new GL2, Joe!
>> Is this normal?
This is normal.
Smoother, slower pans. A good tripod is your friend. When shooting with any camera in progressive-scan mode (like Frame mode) handle the camera like a film camera. That is, use deliberate, controlled motion. It's also best to keep your shutter speed at 1/60.
Search this forum for more info on Frame mode matters. It's a well-worn topic.
Old July 10th, 2004, 12:13 PM   #281
Will Frame mode cause problems converting NTSC to PAL
I have a wedding I'm shooting for a friend here in the U.S. but then I need to convert the footage to PAL. I really like frame mode but I'm worried that it may cause me problems when I convert from NTSC. Any experiences or thoughts? Should I shoot it in normal interlaced mode or use frame mode?
Ryan G. Reed is offline   Reply With Quote
Old July 10th, 2004, 08:13 PM   #282
Mixing Frame Mode & Normal Mode Footage
I was wondering what the result of mixing footage shot with my GL2 in frame mode and footage shot with a PD-100 in 'normal' video mode would be?
Will their be a drastic difference in the way the footage looks? can it be edited together? or shoudl I just shot the footage in normal mode with my GL2?
The reason I ask, is because I was thinking of shooting the more 'dramatic' moments with the GL2 in frame mode.
Toogood Studios
Jeff Toogood is offline   Reply With Quote
Old July 10th, 2004, 10:18 PM   #283
There will be a "drastic difference" between the two. I think the first difference you'll notice is that of color and sharpness. I've not seen footage from a PD-100, but Sony's generally lean toward cooler, more greenish skin tones than Canon. Sony's also tend to produce a sharper image, not always a good attribute but generally a crowd-pleaser.
So to get these two cameras to play nice you'll probably need to skip frame mode on the GL2 and do some color and sharpness adjustments on the GL2 to accommodate the Sony (which may not be as adaptable).
Old July 11th, 2004, 07:18 AM   #284
RED Code Chef
I have no experience but the best tip I can give you is to test your
workflow. If you have other wedding footage shot in NTSC frame
mode convert that to PAL. This firstly tests your NTSC to PAL
conversion methods and secondly how well it will look.
Rob Lohman, visuar@iname.com
Old July 11th, 2004, 08:31 AM   #285
interesting effect
actually, the effect can be very interesting. the viewer will notice immediately but be at a loss to describe it. i've produced documentaries using frame mode as b-roll video for a voice-over and found it to be cool.
Hank Freeman is offline   Reply
