#61 |
Here are some pics in frame and normal mode.
http://homepage.mac.com/bhardy3/PhotoAlbum32.html Just to see, I took some digital photos of the subject with my 2.1 MP Sony camera. They came out kinda fuzzy and lower than normal quality without the flash in the same low light conditions. This says a lot to me about the GL2. |
#62 |
Thanks for the attempt but I'm looking for a comparison of movies in frame and normal mode, not still shots.
<<<-- Originally posted by buddy1065 : Here are some pics in frame and normal mode. http://homepage.mac.com/bhardy3/PhotoAlbum32.html Just to see, I took some digital photos of the subject with my 2.1 MP Sony camera. They came out kinda fuzzy and lower than normal quality without the flash in the same low light conditions. This says a lot to me about the GL2. -->>> |
#63 |
Frame Mode Effecting Sound?
I just purchased a CanonZR40 to temporarily take some of playback brunt off my GL2. I am immediately hearing extreme audio dropout when I play back tapes shot on the GL2 in the ZR40. I usually shoot in Frame mode, so I switched to normal and tested with that-the short test I did seemed to be fine. Is there an obvious reason for this I am not aware of?
#64 |
Outer Circle
Hi David. The only thing I can think of is that the ZR doesn't have frame mode and perhaps cannot properly play bayback GL2 progressive footage? Or perhaps the ZR's heads need to be cleaned?
#65 |
Might be old vs newer tapes. Frame mode relates to how the CCD was read and the DSP applied to the signal off the CCD, not to recording on tape. So frame mode should not effect the ZR-40 playback. The problem you describe is common with LP speed recordings played on another machine. Alternatively it could relate to tape read errors caused by slightly dirty heads, slight differences in tape path allignment between the two machines, or light imperfections in the tape combined the the other two.
#66 |
Hmm. If it's Dirty heads that's easily remedied. All my tapes are SP so that shouldn't be it and the tapes are all Sony Premium and relatively new. If it is a slight alignment difference this is going to always plague me unless I have one of them aligned, no?
#67 |
I would try a head-cleaning tape one time, for about 5 or 6 seconds (no more). See if that clears it up.
CH Search DV Info Net for quick answers | The best in the business: DV Info Net Sponsors | ...Tuesday is Soylent Green Day! |
#68 |
Cleaned the heads and the problem persists-It's strange it's only with material shot in Frame Mode...
#69 |
If you can, try a third machine and see if the issue presists.
#70 |
Frame mode
I'm going to shoot a wedding with my XM2 and I've read that some people use frame mode for this.
I've also read that you have to be carefull with fast moving objects while shooting frame mode ... so, the ceremony shouldn't be a problem, but what about recording dancing people at night? And is it "safe" to use frame mode in low light conditions? (church, evening shots, ...) Something else, is it a good idea to white balance everytime you take a new position during the church ceremony? Or is it better to white balance in the beginning of the ceremony and leave it, even after changing position? Yep, I'm a newbie ;-) |
#71 |
do a search for "Frame Movie mode" or something to that effect. There are lots of post about that subject.
Rob |
#72 |
Outer Circle
I would just shoot in regular mode, but perhaps for some special scenes, use frame mode. This will give it that look. You know. Perhaps experiment with this, and other things before you shoot that wedding. I find a low shutter of 1/30th or 1/15th, for indoor dance scenes, will add a nice blurring effect---but use a tripod for this. Another thing you could do is use a soft filter for special close-ups of the bride and groom. There's lots of things you can do. However, it's better to keep things simple, use a tripod, and vary your shooting angles: high pointing down, low pointing up, etc. Shoot small segments, unless you're going to edit in NLE.
One more tip. Try not to fall into the zooming, panning, and tilting traps. Use these sparingly---or for effect for certain type of scenes---like dance scenes. Good luck with your shoot! |
#73 |
If your intended delivery medium is web video, use frame mode. You'll need to deinterlace anyway if you want to put it on the web, so you might as well do the deinterlacing in real time in-hardware as you shoot.
Yes, it's safe to use frame mode to shoot in any sort of condition that it would be safe to shoot using interlaced mode. All frame mode does is drop the lines from one field and regenerate them back from the other field using interpolation.
All the best, Robert K S Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors |
#74 |
Frame mode does not drop one field and then interpolate from the reaminng field. It uses a sort of vertical pixel shift system sampling from both fields taken at the same instant. The net effect is half way between true progressive and single field interpolation, and it provides better resolution than interpolation of a single field.
In any case, try it and the alternatives before using it on a money shoot to be sure the effect is acceptable to you. As with slow shutter, frame mode can produce good and bad effects on motion, depending on what you want to achieve. |
#75 |
One problem with frame mode though is that the slow shutter speeds, the digital effects ones below 1/50th don't work. They only work in normal mode.
Adrian DVInfo.net Search for quick answers Where to buy? From the best in the business...DVInfo.net sponsors |
