GL2 & XM2 Battery / Batteries - Page 14 at DVinfo.net
Old October 21st, 2004, 11:11 PM   #196
how long can a Power2000 / Lenmar BP-945 power up a GL2?
Gerald Yuvallos is offline   Reply With Quote
Old October 22nd, 2004, 10:49 AM   #197
Anyone? Planning to buy a couple... how does it compare to the Canon BP-945 in terms of performance?
Old October 22nd, 2004, 11:17 AM   #198
Retired DV Info Net Almunus
There is no set answer to your question, Gerald. It all depends on how you use your camera. Reviewing footage in-camera uses more power. Using the LCD consumes more power. Frequent zooming uses more power, too. All I can tell you is that the Power 2000 batteries have generally gotten me through at least a couple of hours. You won't be disappointed with either brand. Both have more capacity than the Canon-branded batteries.
Old October 22nd, 2004, 11:20 AM   #199
Thank you Ken. Off to order a couple now :)
Old January 1st, 2005, 06:28 AM   #200
GL2 Batteries
Hey guys,
I hope I am posting this in the right section, and if not, I am really sorry. My question has to do about the GL2 batteries. On eBay, they sell both the Canon manufactured GL2 batteries (I want the one that last 8 hours, but I forgot the model number) and the batteries which are compatable with the GL2, but not made with Canon. The ones that are not made by Canon are sooooo much cheaper, and I was wondering if buying them would hurt the GL2 in anyway? Are the Canon manufactured ones really worth all the money? What are the pros and cons? Anyways, thanks!
Glen Chua
Glen Chua is offline   Reply With Quote
Old January 1st, 2005, 07:41 AM   #201
The pros are you save money. The cons are that some third party batteries may not be made to the same quality tollerance Canon calls for their name plate.
I use Lenmar betteries with success on my GL1 and XL1. Are they as good as Canon? as far as I can tell there is not a major differnece.
As long as the voltage and current available from the battery is within the normal operating range it should be OK.
dpalomaki@dspalomaki.com
Old January 1st, 2005, 12:45 PM   #202
Ill 2nd the lenmars, ive never had any problems from them on my gl2 or my parents sony camera.
Brian Maier is offline   Reply With Quote
Old January 1st, 2005, 02:09 PM   #203
I've had nothing but good experiences with the Power 2000 batteries I've purchased from B&H. In fact, they have proven to be better than the Canon-branded batteries. The Lenmars would also be an excellent choice. (Note, by the way, that Canon does not actually make their batteries.)
One warning to follow-up on Don's remarks: We've had several people complain about loose fittings with some of the "bought from eBay / bought from a Hong Kong shop for $5" batteries. In my opinion, it's just not worth saving $10-$20 on a battery if it's unreliable or will loose power contact with the camera in the middle of a shoot. Buy the best batteries from reputable dealers.
Old January 4th, 2005, 03:03 PM   #204
I also use the Power2000 batteries. I bought them when I bought my camera from B&H and have had no issues.
The big one lasts forever. In fact I've never actually ran one down all the way before running out of tape(s) or stuff to shoot first.
Charlie Durand is offline   Reply With Quote
Old February 1st, 2005, 12:23 AM   #205
Battery recommendations?
I'm looking for a good generic 3-6 hour battery that lasts to buy instead of the bp-945 (they're kinda expensive). Any recommendations out there?
Jay Stevens is offline   Reply With Quote
Old February 1st, 2005, 12:29 AM   #206
http://www.dvinfo.net/conf/search.ph...der=descending
Old February 25th, 2005, 02:00 PM   #207
Battery trouble (Canon GL-1/XM-1)
Lately I've been having trouble with two Vario batteries I bought for my XM-1 (PAL GL-1). Basically, the last time I tried to use them they only lasted for a couple of minutes.
They're about two years old. The original Canon battery I have is about 5 years old and still going strong. I did use them outdoors at about 0° C, whereas the manual for the new Canon battery I bought today says that it's ideal to use them between 10°C and 30°C.
Does temperature have anything to do with it or can I just throw them in the garbage because they're old?
J.
Jan van den Hemel is offline   Reply With Quote
Old February 26th, 2005, 06:10 AM   #208
RED Code Chef
Sounds like that brand isn't too good. I had some good experience
with Lenmar, although I haven't had them for that long.
The temperature should not really be an issue (at the temps
you mentioned), but they will last a bit shorter at lower
temperatures indeed.
It sounds like they are busted.
Rob Lohman, visuar@iname.com
Old March 19th, 2005, 10:52 PM   #209
GL2 BP-945 Battery Question
My BP-945 , even though it registers fully charged on the Canon CA-920 charger both before and after, goes out seconds after I fire up my GL2. My backup BP-915A is working well. I bought them both at the same time, along with the GL2 and other accessories from Zotz. Any ideas on this? I do use the 945 more but I don't understand why it should do what it is doing.
Sandy
Alexander McLeod is offline   Reply With Quote
Old March 19th, 2005, 11:10 PM   #210
The battery's a goner. Don't waste time trying to revive it. Batteries can die early deaths for a number of reasons. Your observations suggest that this one might have suffered a hard bash, perhaps a bad fall. In addition to the power cells, these batteries contain circuitry that regulates their operation and that can be irretrievably damaged by hard impacts.
If the battery has not suffered such a bash and if it's still new (ex: < 6 months) give Zotz a call. Perhaps they can work something out with you.
