Help (No Audio) Used Mic w/Interviews at DVinfo.net
Old March 14th, 2005, 06:44 PM   #1
I have a GL2 camorder. I recorded a wedding / reception this past weekend and used a hand held microphone plugged into my mic jack during the interview session at the reception. My problem is, the audio came in clear through my headphones and I heard the audio during editing...But when I burned it to a DVD and VHS, NO AUDIO.
What did I Do wrong? I have audio through out the wedding and reception without the microphone plugged in, but no audio with microphone when it burns to DVD or records to VHS.
Help. Bride will be looking for completed DVD in few weeks.
Stephen Shabazz is offline   Reply With Quote
Old March 14th, 2005, 07:26 PM   #2
Capt. Quirk
It isn't a camera issue, but likely a mis-setting in your NLE. What are you using? Can you check the finished avi BEFORE you exported to mpeg?
www.SmokeWagonLeather.us
K. Forman is offline   Reply
